iImage Information
Here is a quick and easy way to make a strand of RGB LEDs for a Christmas tree.
Step 1Buy some color changing RGB LEDs
iImage Information
My friend
Jimmie turned me on to some excellent color-changing LEDs. There are several kinds of RGB LEDs: the ones with four wires are meant to have their colors mixed by a circuit. The ones with two wires change on their own and can't be programmed. But they are fun and perfect for a project like this. I prefer the ones that change slowly, and Jimmie showed me that you can find these on eBay by searching for
rgb slow color change on eBay. They will take a week or more to arrive, which is cutting it close for this Christmas.
These do not require resistors at the voltage I'm using. These LEDs are a bit unusual in that they have a small chip inside of them that is powered by the battery. The chip then powers each individual LED element as it cycles through the color sequence.
I've seen spec sheets for this kind of LED that say 3.8-4.5 V for Vf, and even though I'm underpowering them slightly with the rechargeables (3 x 1.2v), they are plenty bright.
There are a couple US suppliers for these LEDs who have posted spec sheets, but they are much more expensive than eBay. However, if you want to get the LEDs quickly, they may be the best bet:
http://www.elexp.com/opt_hrgb.htm
http://superbrightleds.com/specs/rgb-acc-spec.htm
- Brian
