3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RGB Color Controllable High Power LED Room + Spot Lighting
Step 13Build the user control panel
build the user control panel
if you used dial controls, all you need to do is to drill 3 holes in your panel and screw in the dials.
for sliders, you have to make slots which is a bit tricky. here i used a pre-fab electrical junction box cover which had an appropriate sized cutout already. then i just needed to mount the sliders neatly in the cutout. i spaced the sliders apart evenly using some hex-nuts, and then put them on top of a rigid substrate (a re-cycled chunk of circuit board).
after lining everything up, i poured on some hot-melt glue (make SURE not to get any inside the sliders!). after the sliders were well attached to the rigid substrate, i aligned the substrate against the metal cover and glued them together.
we'll make the front pretty later.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
525
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
