3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RGB Color Controllable High Power LED Room + Spot Lighting
Step 14Connect the control panel to the controller circuit board
connect the control panel to the controller circuit board
1) the connections on the sliders are a bit delicate, so we need to protect them by strain relieving the yellow wires. first glue the yellow wires down near the slider.
2) then solder the yellow wires to the pins on the slider. my slider was rather confusingly marked, testing with my multimeter showed that i should connect to the two pins marked "1".
3) glue an 8-position terminal block to the back of the control panel
4) connect the remaining 8 wires - LED plus and minus, input power plus and minus - to one side of the terminal block. (all the remaining green, white, red and black wires)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
524
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
