Step 15Put a heatsink on the voltage regulators
- i didn't plan ahead! if i'd planned better, i would have been able to use my metal project box as the heatsink for the regulators. as it is, my circuit board sticks out past the side of the regulators so i can't attach them flat to the side of the project box.
- i'm using a chunk of the angle-aluminum for a heatsink, and i cut it so it would fit inside the project box. because of the convenience of using the project box as a heatsink, aluminum project boxes are ideal. as an alternative - if you have any old or broken computer power supplies around, these power supplies always have several heatsinks inside them which are the exact size for the regulators (TO-220 package) that we are using. even better, they will usually have heatsink insulators also.
- the metal tabs on the regulators are NOT electrically insulated. since we're connecting all three to a single heatsink, we need to insulate them electrically from the heatsink. you can find recycled heatsink insulators in an old computer power supply, or you can just use a piece of thin mylar (polyester) - refer to the LED mounting step for more details heatsink insulators.
- if you want to handle a full 300+ watt light, you'll need to use thermal compound here. you'll be putting up to 20 watts out of a single regulator. if you're only making a 50-100 watt light, just the silicone glue should be fine.
- using silicone glue: put glue on both sides of the insulator, and glue down the regulators. clamp them down until it is dry to ensure a good connection. after it is dry, also glue the heatsink directly to the circuit board so the assembly is rigid - you need to make sure the regulators can't pry themselves off the heatsink by accident.
- using thermal compound: drill holes in the heatsink to match the holes in the regulators. put thermal compound on both sides of the insulator. screw down the regulators using a nylon (insulating) screw, or else a metal screw with a nylon bushing around it (they are made specially for this purpose). see how much simpler it is to just use silicone glue?
- below i used the thermal-compound method.
Add Comment
