3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RGB Color Controllable High Power LED Room + Spot Lighting
Step 16Connect external wiring
connect external wiring
1) install a strain relief in the side of your project box. electrical junction boxes are convenient because they are designed for this and you can buy strain reliefs sized just for the purpose. first pop out the correct sized hole in your junction box (this usually needs a hammer). then attach the strain relief to the hole.
2) feed the power cable and the 6 wires from the LED's through the strain relief, with about 6 inches inside the box. tighten down the strain relief to clamp the wires.
3) attach the wires to the terminal block. use a multimeter to check that you've connected the LED positives and negatives correctly.
4) before connecting the power cable, it is convenient to test the circuitry using your bench power supply. you can test safely by slowly increasing the input voltage with a 250mA current limit, to check for shorts, miswiring, etc.
5) if you are using a laptop power supply, note that these power cables usually are coax - the positive wire is in the core of the cable with an insulator around it, and the negative wire is all around the insulated positive wire. that makes it a little tricky to strip correctly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
525
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
