Step 5Heatsink selection
all the LED's will need to be attached to a heatsink in order to run at full brightness. in fact, without any heatsink at all the star-LED's can only run at about 2/3-watt each!
so a heatsink is just a piece of metal? YES! this is your opportunity for creativity and recycling. the heatsink will be large (much larger than you expect), so plan on it being the main structural element of your lamp. if your metal frame will be visible, you can use a piece of decoratively shaped metal.
- use a highly-conductive metal for your heatsink: aluminum, brass or copper. steel does not conduct heat very well - you can use it but you'll need a thick piece. scrap aluminum is easy to come by, and there are also many inexpensive sources for it at your local hardware store if you know where to look - rain gutters, various metal trims.
- how big a heatsink do you need? use this rule of thumb: minimum 10 square inches of exposed metal surface per watt of LED power. you can see in the photo that i used a piece of angle-bracket aluminum. my piece is 45 inches long, 1/8" thick, with 2" width on each side of the angle. that gives me an exposed surface of 45 x 2 x 2 x 2, or 360 square inches. count both sides of a sheet of metal only if both sides are exposed to the air. using this rule of thumb, your heatsink will run about 30 degrees C hotter than the surrounding air temperature at full power. keep in mind that the LED's internal temperature will be another 40-50C hotter than that. if you need a smaller heatsink, the only options are to use fins (which fit the same surface area into a smaller volume), or to use a fan. the rule of thumb here assumes "free air convection". if your heatsink will be in an enclosed space where the surrounding air will get hotter than 25C, then you need a bigger heatsink or a fan. advanced: try this handy calculator: http://www.frigprim.com/online/natconv_heatsink.html
with this calculator you can approximate most odd chunks of aluminum as a 2-fin heatsink with equal total surface area.
- how much is your LED power total? multiply: 3.8V per LED x LED current x number of LED's. for my lamp that's 3.8V x 0.8A x 15 = 46 watts, so i'm a little on the hot side.
- you need enough FLAT area on the heatsink to mount all the LED's. the mounting area must be perfectly flat to ensure good heat transfer between the LED and the heatsink. if your piece of metal is so thin that it can flex, then it will need some support or protection - you don't want an LED peeling off the heatsink under full power, it will burn out immediately.
comments
Add Comment
Add Comment
