3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RGB Color Controllable High Power LED Room + Spot Lighting
Step 8Attach LED's to the heatsink
attach LED\
I used the 1-watt star LED's, these have an insulated backing plate so you just glue them straight onto the heatsink, no worries. if you are using 3-watt stars, you need an electrical insulator between them and the heat sink.
the "pro" way to attach components to a heatsink is: use thermal compound between the component and heatsink, add a special heatsink insulator layer if electrical insulation is needed, and screw down the component with nylon screws (or metal screws with a nylon bushing)
the "pro" way is a lot of work because you need to drill a lot of holes, and the special heatsink insulators are about $1 a square inch (let me know if you have a lower cost source!). luckily, the "pro" way is really a huge overkill here and we can do this much easier. why? the surface area of the luxeon star is large, and each LED is only about 3 watts. that's about 50 times less demanding thermally than a computer CPU.
so what's the easy way? we'll just glue down the stars using silicone glue. it works great. if you need a heatsink insulator, the best low-cost version of this is: thin mylar (polyester) film. most likely you already have some as reflective static-shielding bags, window-tinting film, or clear packing tape (although the glue on the tape is unsuitable, remove it with paint thinner). it is important to use mylar, other common plastic films will melt.
you need to use a flexible high-temperature glue, "GE Silicone-2" is ideal for this. press hard on the LED and squish it around a bit when you glue it down, you want as thin a layer of glue between the LED and the heatsink as possible & no air bubbles, to maximize thermal conduction. if you are using 3-watt stars, you need glue fully covering both sides of the insulator. use a little excess glue to make sure the entire contact area is glued (you can see where my glue is all around the sides of the LED after i squished down on the LED's).
- attach your LED's in groups of 3, each group has 1 red, 1 green, 1 blue LED. spread out the groups around the heatsink for best heat transfer.
3 comments
Apr 11, 2007. 8:57 PMbabylonfive says:
I agree with morcheeba, that whatever custom attachment method you use, try it out once and see how it does.
Also, better adhesive isn't that much more expensive... a combination of some lousy-cheap PC heatsink grease in the middle and silicone on the outside is a great example of a different technique that might work better. It's really ok - no sweat if someone does it different...
Jan 8, 2007. 12:03 PMmorcheeba says:
I'd recommend attaching one LED and running it at full power for a while to make sure that your attachment/heatsinking method is good before you do the rest of the LEDs. Three watts is nothing to take lightly -- they'll easily burn your fingers if they aren't heat sunk. (yep, I did that!) There are thermally conductive epoxies (basically epoxy with little bits of metal in it), so that may be an option. Check the electrical conductivity of this epoxy before using it with the 3W LEDs.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
525
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
