3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RGB LED Color Sequencer - without a Microprocessor
Display the color combinations of color LEDs without using a microprocessor.
Using a single logic chip which costs under 50-cents, you can make a simple color cycle display for RGB LEDs. The multiple taps along the top are used to 'program' the display for sequence and brightness.
Step 1The parts
The parts
You will need:
RGB LED - I used one purchased here. This is a common anode version, so if you have a different configuration, you must adjust the connections.
1 x 74HC04 Hex Inverter IC chip (p/n 771-74HC04N, by NXP is 30-cents at Mouser)
3 x 0.1uF capacitors
R1 - 10M-ohm resistor
R2 - 6.8M-ohm
R3 - 3.3M-ohm
R - 12 pcs of 100-ohm resistor for the Programming tree. I used 120-ohm resistors which I got free.
2 x "AA" batteries and suitable holder.
Perfboard, wire, supplies, etc.
I've also used sockets for the IC and the LED, which I've found to be quite sensitive to heat.
28 comments
Dec 27, 2011. 11:33 AMKikiTay says:
Hey,
Check out this LED Sequencer!
i've tried making my own and gave up, I spent a lot of money buying those kits on ebay but they are either too complicated or can only power a few LEDs at less than normal brightness. I found this circuit that solved my problems! I bought a few and used them to make LED costumes and many of my RC hobby and robotic projects. Pretty straight forward and easy to install though. I found a similar one on ledsequencer.com but there's no links to buy it. hope it helps! here's the link!
http://www.specialeffectsmagic.com/12_Channels_LED_SequencerChaser_KT01_EXCLUSIVE/
May 22, 2010. 2:04 PMkameu says:
Will a 74LS04 work?
Oct 19, 2011. 3:20 PMsgleason1 says:
I can use a 4049 in place of the 74hc04 am I correct ?
Oct 19, 2011. 5:08 PMsgleason1 says:
Alright thank you, i know that the 4049 pinouts are different, but what do you mean about voltage, do you use 5volts, because the 4049 can handle that, and what is the point of the 3 different resistors, i was going to use 3 10m ohm resistors, what will it change?
Oct 19, 2011. 6:49 PMsgleason1 says:
alright i just stiched this together using 2 10mohm resitors, the only thing is they are all channging at a desirable rate, but they only change on and off, they dont fade, when i put more or less capacitance in they just stay lit, how would i get the fade effect?
Dec 2, 2010. 9:11 AMthebanano says:
hallo again...
could that be the speed and the brightness controller is change with a dial/pot?
Nov 19, 2010. 11:33 AMthebanano says:
hallo qs..
nice work again...
by the way, i want to know that, if can i use 3 (rgb) single 3 mm led for replacing the led that you are using?
it is hard to find that superflux led on my little town,
sorry for my english...
Oct 11, 2010. 5:25 AMElectroinnovation says:
Will this make a smooth slow transition between colors or does it quickly change colors?
Oct 11, 2010. 10:26 AMElectroinnovation says:
Okay thanks
Aug 3, 2010. 1:06 AMjust smile says:
does the circuit reset itself and start the sequence again.
Sep 17, 2010. 1:05 AMskyhell2009 says:
why this circuit must have 12 pcs of 100-ohm resistor..??
May 2, 2010. 7:43 PMKDFAN says:
How could you wire it so that you could connect multiple LED's in a row. Would you have to connect more BLC (Basic Logic Chips)?
Mar 29, 2010. 11:01 AMmischka says:
Very cool circuit, i like the way people use logic chips.
Feb 5, 2010. 9:07 AMfupersly says:
Hey qs - little confused - does this circuit actually change colors as a function of time?  Or is it a fixed color you program via setting the jumpers?  The hex inverter oscillators I've seen are a fixed so I cannot figure out from the description how the device would change frequency of the R,G,B leds over time in order to cycle through colors.
Feb 5, 2010. 11:19 AMfupersly says:
 Each oscillator runs at a fixed frequency?  The color changes are due to the oscillators running out of phase?
Sorry - almost there to getting it!
May 25, 2009. 6:34 PMSagar Gondaliya says:
could you send me two separate pics of the schematic and board?
May 23, 2009. 3:05 PMinventorjack says:
Cool little project. Basic logic chips are fun to work with, and a great way for people to get started in electronics. Also, I have to say that that picture with the sketch overlay looks awesome, and really helps to explain it in a way that just a picture of the board and just a sketch might not.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:qs
