Remove these ads by
Signing UpStep 1: Parts Needed
Parts:
Poster Board (found at Micheal's arts and crafts)
5mm RGB LED's (I bought at www.besthongkong.com, also at Fry's Electronics)
Resistors for my project I used 330 ohm 1/4 watt resistors, but whichever kind you need for your LEDs, how I have found out is by going to http://led.linear1.org/led.wiz which is a LED calculator, you plug in your information and it tells you the array and what resistors to use. (I bought at www.besthongkong.com, also at Fry's Electronics)
Copper Tape (found at Micheal's arts and crafts)
Wire (found at Fry's Electronics, but I am sure Radio shack has them too)
9 volt battery harness (found at Fry's Electronics, but I am sure Radio shack has them too)
9 volt batteries (found at Fry's Electronics, but I am sure Radio shack has them too)
Choice of wood 1x4x8 (Home depot, Lowe's)
L shape metal Brackets (Home depot, Lowe's)
Screws fir Bracket (Home depot, Lowe's)
Fogged Plexiglas (or clear Plexiglas sanded with medium grit sand paper) (Home depot, Lowe's)
Tools:
Wire Cutters
Soldering Iron
Hot Glue Gun
Skill Saw, or Chop Saw
Screw Driver
Drill
Carpenters square or Ruler
Visit Our Store »
Go Pro Today »
How long after powering on does it degenerate into a random pattern? Any chance of uploading a video from the moment of powering-on so we can see?
I'm working on something similar, but plan on turning them on at different intervals. This way there is a clearly defined pattern at power, but then degenerates into the randomness as your box does.
The LEDs' themselves are not regulated that well when being made so when they fade from one color to another the timing is off a little bit, which quickly makes them off pattern, then leads to the randomness. I hope that helps!
10 seconds? Wow... that's much faster than I am seeing with mine so far. I've got a lot of 500 here, and in my testing, they seem fairly consistent.... 20 slapped on a breadboard sees about 10-15 of them hold a decent sync for upwards of a minute. Although time-consuming, and if need be, I could test, sort, and group out the ones that appear to have similar timing. Im using 121 (11x11) of my 500 for this project, so I've got more than a handful to pick from.
Like stated above, having the pattern at power-on is one of the main points of my project (through tinkering with adjustable delay circuitry) ... seeing it degrade is part of the goal, but doing so in under 10 seconds will be disheartening. I guess I'll find out more as I progress.
Again, thanks for the reply!
Since my local electronics store only had 16 chameleon Leds (RGB's), i bought 16 and im gonna make it 4x4, but the question is, im gonna have 2 arrays, of 8 chameleon Leds each, Should i use 150 ohms resistors and power each array with a 9V battery? or what resistors should i use? Thanks in advance for your support!
It is nice, simple, and easy to use. On that note, if your LED needs 3.4 volt 20mA and is being pulled from a 9volt battery you should use 330ohm 1/4 watt resistor for each LED. I see I wrote 150Ohm resistors in the instructable, but that would be if you wired two LEDs to each resistor, but in the case of working with "flashing" LED's you do want a resistor to each LED. Sorry for the confusion, and I fixed the mistake in the instructable (oops!). Hope that answered you question, and let me know how else I can help!
I hope that clears up everything, and again, trust the LED calculator, when in doubt with anyone's projects use the LED calc. You never know what the circumstance is with whoever is making the project, my 150 Ohm resistors is a prime example!
totally loving the project though!!! It looks epic, and I'm totally going to try to do this! Been looking for a long time for a good LED project, and this looks like fun! ^^ Thanks for making this tutorial!
Thanks!
So essentially for each LED you have a Positive wire coming from the positive side of the battery to the positive side of the LED. And then a negative wire coming from the negative side of the battery going to the resistor which is attached to the negative side of the LED.
If that is not clear enough I can sketch something out, hope that helps!
c
I guess I am just wondering what an experienced person would do. I am just getting into the LED projects myself. I did make this box already, with great results! Now I want to take this concept and expand. I appreciate the time you put into this! Definitely falling in love with this new hobby.
As far as what you are wanting to do, you can use any voltage that will power the LED's. And then like you said just make sure that you have enough amps to cover all the LED's and that you are using the appropriate resistors for the voltage you chose.
When hooking up that many LED's I am sure there is a more efficient way to go about it, I just am not advanced enough in the electronics to know how. But this will work for large amounts of LED's! When you get it all done please post a video, I would love to see it. If you have anymore questions please let me know!
I would like to install this into my car and not have to run off 9 volt batteries, is there a way to hook it up to the car battery?
Ive never worked with individual LEDs before, any change to the resistors or anything else needed for hooking it up to my 12v car battery?
Thanks for your time!
Hooking up the LED's to your car is the same thing as what I made, just using a higher voltage, let me know if I can help you further!
Is there somewhere like a tutorial that you know of that would help me to figure out how many I could run in sequence and the resistors?
I tried looking at other articles on here and everything was like how to hook up 1 or 2 LEDs not quite the big scale Im going.
I also tried using the LED calculator you referenced but the array it shows is only 3 and 4 wide I need 9x7.
Thanks again sorry for the long reply.
Solution: 3 x 21 array uses 63 LEDs exactly
So you can put 3 LEDs in a row with 1 - 100Ohm 1/4 watt resistor, and just duplicate that 21 times and you got your 63 LEDs! Hope that helps!
http://cgi.ebay.co.uk/50-Pcs-5mm-Slow-Red-Green-blue-RGB-LED-Rainbow-free-R-/120647874248?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item1c172c76c8
