Step 4Prepare Board
Now that you have it all laid out, grab a drill and drill bit. Choose drill bit size that is a little smaller then the end of the led itself, example: if you are using 5mm LED's then maybe go for a 3 or 4 mm drill bit. Now in the center of each box you should have an X, and at the cross of the X should be the very center of each box. So that is where you need to drill the holes!
Add Comment
