Well, I feel like I am a pretty regular guy... I work in the Entertainment industry, right now am working for Lucas Animation on a Top secret assignment ;). I love to create things, and build things ...
Well, I feel like I am a pretty regular guy... I work in the Entertainment industry, right now am working for Lucas Animation on a Top secret assignment ;). I love to create things, and build things so this site is one of my regular places :) I also enjoy going out doors, like playing in the dunes on my quad, or going on motorcycle rides with friends, Soccer, Rock climbing, mountain biking, camping etc...
more »
How long after powering on does it degenerate into a random pattern? Any chance of uploading a video from the moment of powering-on so we can see?
I'm working on something similar, but plan on turning them on at different intervals. This way there is a clearly defined pattern at power, but then degenerates into the randomness as your box does.
The LEDs' themselves are not regulated that well when being made so when they fade from one color to another the timing is off a little bit, which quickly makes them off pattern, then leads to the randomness. I hope that helps!
10 seconds? Wow... that's much faster than I am seeing with mine so far. I've got a lot of 500 here, and in my testing, they seem fairly consistent.... 20 slapped on a breadboard sees about 10-15 of them hold a decent sync for upwards of a minute. Although time-consuming, and if need be, I could test, sort, and group out the ones that appear to have similar timing. Im using 121 (11x11) of my 500 for this project, so I've got more than a handful to pick from.
Like stated above, having the pattern at power-on is one of the main points of my project (through tinkering with adjustable delay circuitry) ... seeing it degrade is part of the goal, but doing so in under 10 seconds will be disheartening. I guess I'll find out more as I progress.
Again, thanks for the reply!
Thanks!
So essentially for each LED you have a Positive wire coming from the positive side of the battery to the positive side of the LED. And then a negative wire coming from the negative side of the battery going to the resistor which is attached to the negative side of the LED.
If that is not clear enough I can sketch something out, hope that helps!
c
I guess I am just wondering what an experienced person would do. I am just getting into the LED projects myself. I did make this box already, with great results! Now I want to take this concept and expand. I appreciate the time you put into this! Definitely falling in love with this new hobby.
As far as what you are wanting to do, you can use any voltage that will power the LED's. And then like you said just make sure that you have enough amps to cover all the LED's and that you are using the appropriate resistors for the voltage you chose.
When hooking up that many LED's I am sure there is a more efficient way to go about it, I just am not advanced enough in the electronics to know how. But this will work for large amounts of LED's! When you get it all done please post a video, I would love to see it. If you have anymore questions please let me know!
