3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RGB LED Moodlight in 10 minutes!
Here is my 2nd. Instructable. A very quick one! ;-)
I will show you how to build a nice 3-RGB-LED mood light in nearly 10 minutes.
What did you need?
- battery powered LED touch-light
- slow rainbow effect RGB LEDs with slow automatic color cycling (or fast if you like ;-)
- small screw driver (depends on your LED touch-light)
- soldering-iron
Step 1Look what is inside the touch-light
look what is inside the touch-light
First I remove the batteries from the bottom side of the lamp.
With my fingernails I can grip between the upper silver and the lower black part and simply lifting it up.
Then the rest of the parts dissolve them self. Really cheap build lamp ;-).
On the 3rd picture you can see the small PCB with 3 white LEDs and in the switch in the middle.
32 comments
Apr 24, 2009. 10:55 PMPineapple_D says:
I know this sounds stupid but how do you change the colour? do you press it or what???
Nov 9, 2010. 8:17 AMAdam Manick says:
Radio Shack sells an RGB led that changes color when you connect its ground and trigger pins together. You can put a push button between them. Here is the link if you want to check it out.
http://www.radioshack.com/product/index.jsp?productId=3060680&numProdsPerPage=60
May 16, 2009. 10:11 AMmnc says:
there is different kind of leds changes colour according to:
  • depends on time, (changes by it self)
  • electric way if you swap + and - it changes colour
  • according to watt/volt im not sure.
Jun 25, 2009. 7:15 AMMilotisX says:
hey do you know the name of the second type you mentioned??
Jul 7, 2009. 10:10 AMDerin says:
bicolor led
Jun 25, 2009. 1:53 PMmnc says:
sorry I don't know, try to asking "low power colour changing led" or "two colour led"
Apr 18, 2010. 1:35 AMcokecola says:
The first image looks real cool, is that just a drinking glass over the top of the lite?
Sep 6, 2010. 12:14 PMWesley666 says:
No its a single LED taken very close up.
Feb 2, 2009. 3:06 PMDryank04 says:
so is there a difference between a RGB slow flash LED and a RGB color cycling (slow)? i cant find one that says color cycling they all tend to say 'flash' but flash makes me think it wouldn't be a smooth transition to the other colors.
Jul 13, 2009. 1:20 AMQuestioneverything13 says:
I got some slow flash rgb leds from ebay and they fade slowly from one colour to the next but the fast flash rgb leds I got at the same time flash real fast from one colour to the next and just give you a headache. Sureelectronics sell them in lots of 100 with 100 X 470ohm and 100 X 100ohm resistors but that is a lot of leds.
Nov 28, 2009. 5:08 PMabbtech says:
You can get them individually here (on sale right now also).
http://alan-parekh.vstore.ca/product_info.php/products_id/88
There is a video that demonstrates the RGB LED color cycling, fast flash and slow cycle in one device.
Aug 31, 2008. 6:27 PMjohnny q says:
where do you get the touch light that you are starting with ? What type of store would sell one ? The raw light itself looks really neat, kinda like a crystal ball. I haven't tried any projects from here, but this one could be the first. I sure like it.
Mar 26, 2009. 1:10 PMPhoghat says:
A lot of drugstores have them
Jan 17, 2009. 9:19 AMwoodswalker says:
I'd like to build a small LED art piece from scratch using the drawing above. What voltage of battery are you using? (with no resistors I'm guessing it's 4.5?)
Dec 26, 2008. 8:28 AMdidibemi says:
really nice but i think you can buy that rings or others that have this device. they're cheaper. aushuashuashasuhash
Oct 30, 2008. 3:55 PMCarlos Marmo says:
Wonderful Work! Congratulations!
Sep 30, 2008. 1:00 PMprototype27 says:
Very cool! I actually use these all over the place as accent lights, but instead of diffusing with paper under the lens I just scuff it up a bit with sandpaper. Good job.
May 12, 2008. 9:18 AMArtificial Intelligence says:
I have all the parts I need to make this. Never thought about make something like this. It's cool and simple. Thanks
Feb 27, 2008. 8:27 PMPaulcet says:
Where does one find the 'automatic' RGB LEDs?
Feb 27, 2008. 5:47 PMGorillazMiko says:
Pretty cool! It is as if you diffused the LED. ;-) And wow, look at the related Instructables.. most of them are all black in the back!
Feb 27, 2008. 6:53 PMPyrowuzzup says:
thats a good idea reusing the touch light body. do rgb leds always start on the same color or do they go out of sync with eachother?
Feb 27, 2008. 7:32 PMjoejoerowley says:
My RGBs start at the same color and then eventually go out sink after a while.
Feb 27, 2008. 8:29 PMPyrowuzzup says:
Eventually theyll probably get em where they all stay synced.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:WattSekunde
