Introduction: RGB LED Strip Controlled by Voice
In this instructables, I will show you how to implement a voice controlled RGB LED strip. After we have built the project, we will be able to control the color of the RGB LED strip and its intensity by voice commands. It sound exciting, is not it? Let's see how it works!
Step 1: How It Works?
We need to connect the RGB LED strip to Arduino Nano using a breadboard. To propel a strip, an external power supply is required connected to the strip. After we have attached the Arduino to Raspberry Pi via USB, we need to upload a control code to it. It allows to control the Arduino microcontroller for Ozeki 10 what is a messaging system that routes messages between entities installed on Raspberry Pi. We also need a microphone with a sound card attached to Raspberry. Finally, we need to compile and run a few lines of code in Robot Controller (that is a built-in app in Ozeki 10) and we will be able to get a voice controlled RGB LED strip. Let's look at these steps in more detail!
Step 2: Accessories
For this project, we need the following components exactly:
- Raspberry Pi 2 or 3
- USB sound card with microphone
- Installed Ozeki 10 on Raspberry Pi
- Arduino Nano
- 3 MOSFET NPN transistors
- LED strip
- Breadboard
- Jumper wires
- Power supply
Let’s get started!
Step 3: RGB LED Strip Control Switch on Breadboard
LED strips are very simple, so easy to use them with any microcontroller such as Arduino Nano. I suggest using PWM dimming techniques to control the strip. Each LED pin may end up requiring an Amp or more to sink to ground. Because of this, we need to use power transistors. Do not try to connect the pins directly to your microcontroller, they will burn out and/or not work!
However I use IRF540N MOSFET, you can use any power NPN or N-Channel MOSFET, but make sure the used transistor is rated to be able to pass as much current as you need. For example, since we draw about 0.2Amps per channel per meter, if you have a 5 meter strip you will need to pass up to 1 Ampere per transistor.
The diagram above shows how to connect with N-Channel MOSFETs where the Gate is pin 1, the Drain is pin 2 and the Source is pin 3.
To write this step, I used the content of https://learn.adafruit.com/rgb-led-strips/usage website.
Step 4: Format Arduino Nano
Why should we format? Arduino microcontrollers have a built in memory called EEPROM whose values are kept when the board is turned off. When you get a new Arduino, this storage is often filled with garbage. So we need to clear this storage before uploading a control code to it.
For formatting, we need its own software called Arduino IDE that you can download at https://www.arduino.cc/en/Main/Software. After you have installed it, connect Arduino to your PC via USB. Before uploading, make sure you have properly set up the application: under Tools menu, you have selected Arduino Nano as a Board and have set the Port that the device connects to (it is COM6 for me).
In this step, the last thing is to upload the formater code, that you can find below, to your microcontroller. Copy then paste it into Arduino IDE then click on Upload button.
#include <EEPROM.h>
int a; void setup() { pinMode(LED_BUILTIN, OUTPUT); Serial.begin(115200); for (uint16_t i = 0; i < EEPROM.length(); ++i) { EEPROM.update(i, 0); } for (uint16_t i = 0; i < EEPROM.length(); ++i) { a+=EEPROM.read(i); } if (a == 0){ Serial.println("EEPROM is null! The process was successfull!"); } else if (a > 0) { Serial.println("EEPROM is not null, please upload the code again!"); } } void loop() { if (a == 0){ digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW delay(1000); } }
Step 5: Install Ozeki 10
Before installing, let me say a few words about what Ozeki 10 software is. This is a messaging system that routes messages between real world entities. We can build up a communication between shared hardware such as Arduino Nano and software resources. It has a built-in software called Robot Controller that we will use for sending messages to Arduino. Thanks to this, we can easily implement our voice controlled RGB LED strip with a few lines of code after we have finished the configuration.
So, the guide to download and install Ozeki 10 software on Raspbian OS is available at http://www.ozeki.hu/index.php?owpn=3095. After you have downloaded and installed it, connect with your PC to Raspberry via WiFi. I consider it important to mention that the Ozeki 10’s surface is only accessible through a web browser, because it runs as a service, so you need one in witch you can login into it and can configure or manage the system.
By the way, you can build this system without using Raspberry Pi. In this case, you only need to install the Windows or Ubuntu Linux installer to your PC that you can download via http://www.ozeki.hu/index.php?owpn=3091.
Step 6: Upload a Control Code to Arduino Nano
Ozeki 10 system controls this microcontroller using text messages. To enable for this microcontroller to understand these messages, it is necessary to upload the control code to it.
Like in the previous step, copy the following code into Arduino IDE then upload it to the hardware.
#include <OzIDManager.h><br>#include <OzRGBLedController.h><br>
// global pointers
OzIDManager* manager;
OzRGBLedController* rgbController;
// please select PWM pins
const int redPin = 3;
const int greenPin = 5;
const int bluePin = 6;
const int pwm = 9;
void setup()
// wait for serial port
// instantiate objects
manager = new OzIDManager;
manager->_sendACK = true;
manager->_checksum = true;
OzCommunication::setIDManager(manager);
rgbController = new OzRGBLedController(redPin, greenPin, bluePin);
rgbController->setPWM(pwm);
int x=1;
manager->sendLinkSetup();
manager->PrintWelcomeLine(rgbController, x++, "MyRGBLed");
void loop()
OzCommunication::communicate();
}Step 7: Login Into Ozeki 10
Connect with your PC to Raspberry via WiFi then open a web browser and navigate to the Raspberry's 9505 port. You will see the Ozeki 10 Login page. Enter your password that you specified during the installation then click on OK.
If you installed it to Windows or Ubuntu Linux and do not want to use Raspberry Pi, open localhost:9505 in your internet browser.
Step 8: Open Robot Controller
Robot Controller is a built-in application in Ozeki 10 in witch we can control and manage all the entities connected to the system. We can send messages to the entities and of course, we can receive messages from them using Subscribe method (that we will talk about in Step 11).
The software detect all the entities connected to the system included Arduino Nano as an RGB LED connection.
Step 9: Configure Speech to Text
Time to configure the Speech to Text connection. After we have created, we will be able to set words or a word set to detect using microphone. To do this, we need to open Connections and create a new one for the microphone as a Speech to Text type of connection.
First, navigate to Tools on manubar then select Connections item. In this Connection view, you can see all the connected entities. We will create a new one for the microphone. To start this, click on Create new Connection button. On the right side panel, you can choose what type of connection you would like to add, now we need AV (Audio or Video) then select Speech to Text. Then name it as My_Speech_to_Text_1, select your microphone as a recorder device and choose speech recognizer as English. Finally, set the accuracy level of the speech recognition to 80 percentage.
If you does not have English option, you need to install the English language pack to your system.
Step 10: Set Detectable Word Set
Then we need to create a detectable word set to load the color names to be detected. To do this, in the Connection view, select the My_Speech_to_Text_1 connection's Details button then navigate to Detect words tab and click on Create new Detectable word button. On the right-side panel, select the Word set then the Colors option. Finally, name it as Colors and click OK.
Click on Home button to return back to Robot Controller.
Step 11: Run the Code in Robot Controller
Running the code below, it will turn the color of the RGB LED strip to green then red and vice versa 10 times. After that, it will subsribe to My_speech_to_Text_1 connection, that we had created before, using the Subscribe method. So, when we say a color name into the microphone, the Text to Speech connection will recognize it then convert it into a simple text message what we will catch throught Receive method using its Message parameter. In this method, we can filter the name of the connection using FromConnection function. If it comes from the configured mirophone, we will transmit this message to our Arduino microcontroller using the Send method. Finally, our RGB LED strip will light up and pick up the spoken color.
Copy this code then compile and run it. Now, you can use your microphone to control RGB LED strip’s color saying color names.
using System;<br>using System.Threading;
namespace Ozeki
public class Program
public void Start()
for(int x=0; x<10; x++)
Send("MyRGBLed@localhost", "green");
Thread.Sleep(500);
Send("MyRGBLed@localhost", "red");
Thread.Sleep(500);
Subscribe("My_speech_to_Text_1@localhost");
public void Receive(Message msg)
if(msg.FromConnection=="My_speech_to_Text_1@localhost")
Send("MyRGBLed@localhost", msg.Text);
};Step 12: Testing the Solution
First, we will test the Speech to Text connection that you can see on Test 1.
After you have compiled and started to run the code, you will see a --- Subscribe My_speech_to_Text_1@localhost message on the console. Then you need to say a color name into your microphone, for example: red. In this case, a message should appear on the console: --> (My_speech_to_Text_1@localhost) Red. This means that the Robot Controller received a message containing a Red message from Speech to Text connection.
Finally, we will test the MyRGBLed connection that you can see on Test 2.
After the Robot Controller successfully received a message from Speech to Text connection, it should transmit a received message to MyRGBLed connection: <-- (MyRGBLed@localhost) Red. Then the RGB LED strip should light up and should change its color to red.
