Step 5Analog Arduino Code
To do this each LED requires 3 PWM pins. As the Arduino has only 6 PWM pins only two RGB LEDs can be controlled this way at a time.
In terms of the code we will use the analogWrite(pin, value) function, for more details visit the code reference on Arduino.cc )
To get playing with the your LEDs in an Analog manner simply...
- Copy and paste the code below into an empty Arduino sketch
- Compile and upload the sketch to your Arduino board
- Example one will start by turning the LED magenta (you can then play around with the colour to change it to other presets, or define your own)
- Next comment out the Example 1 line (add //)
- Un-Comment Example 2 (delete the //)
- Compile and upload the example to your board.
- Now watch as your LED turns a whitish green colour, change the numbers in the tempColor[] array to change the displayed colour
- Comment out Example 2 (add //)
- Uncomment Example 3 (delete the //)
- Compile and upload the program to your board
- Watch as the LED fades from Red to Green To Blue. To see how this is accompished look to the fadeToColor() function
- Next get coding and making your own fun colour changing programmes
Appendix 1: _RGBL_AnalogTest
//---bof---RGBL-Analog Preamble//RGB LED pinsint ledAnalogOne[] = {3, 5, 6}; //the three pins of the first analog LED 3 = redPin, 5 = greenPin, 6 = bluePin //These pins must be PWMint ledAnalogTwo[] = {9, 10, 11}; //the three pins of the second analog LED 9 = redPin, 10 = greenPin, 11 = bluePin //These pins must be PWM//Defined Colors (different RGB (red, green, blue) values for colors//(to add your own ie. fuscia experiment and then add to the list)const byte RED[] = {255, 0, 0}; const byte ORANGE[] = {83, 4, 0}; const byte YELLOW[] = {255, 255, 0}; const byte GREEN[] = {0, 255, 0}; const byte BLUE[] = {0, 0, 255}; const byte INDIGO[] = {4, 0, 19}; const byte VIOLET[] = {23, 0, 22}; const byte CYAN[] = {0, 255, 255}; const byte MAGENTA[] = {255, 0, 255}; const byte WHITE[] = {255, 255, 255}; const byte BLACK[] = {0, 0, 0}; const byte PINK[] = {158, 4, 79}; //---eof---RGBL-Analog Preamblevoid setup(){ for(int i = 0; i < 3; i++){ pinMode(ledAnalogOne[i], OUTPUT); //Set the three LED pins as outputs pinMode(ledAnalogTwo[i], OUTPUT); //Set the three LED pins as outputs } setColor(ledAnalogOne, BLACK); //Turn off led 1 setColor(ledAnalogTwo, BLACK); //Turn off led 2}void loop(){/* Example 1 - Defined Colors Set to a known color (you can use any of the above defined colors)*/ setColor(ledAnalogOne, MAGENTA); /* Example 2 - Any Color Set the LED to any color you like*/ //byte tempColor[] = {12,34,12}; //the RGB (red, gren blue) value for a color to display //setColor(ledAnalogOne, tempColor); /*Example 3 - Fading Fade the LED between two colors (this will go from red to green to blue then back to red)*/ //fadeToColor(ledAnalogOne, RED, GREEN, 10); //fadeToColor takes 4 parameters //ledAnalogOne - an array with 3 values defining the red, green and blue pins of the LED //RED - This is the start color //GREEN - This is the end color //10 - the delay (in milliseconds between updates) (determines the fade speed) //fadeToColor(ledAnalogOne, GREEN, BLUE, 10); //Fades from Green to Blue //fadeToColor(ledAnalogOne, BLUE, RED, 10); //Fades from Blue to Red}/* Sets the color of the LED to any RGB Value led - (int array of three values defining the LEDs pins (led[0] = redPin, led[1] = greenPin, led[2] = bluePin)) color - (byte array of three values defing an RGB color to display (color[0] = new Red value, color[1] = new Green value, color[2] = new Red value*/void setColor(int* led, byte* color){ for(int i = 0; i < 3; i++){ //iterate through each of the three pins (red green blue) analogWrite(led[i], 255 - color[i]); //set the analog output value of each pin to the input value (ie led[0] (red pin) to 255- color[0] (red input color) //we use 255 - the value because our RGB LED is common anode, this means a color is full on when we output analogWrite(pin, 0) //and off when we output analogWrite(pin, 255). }}/* A version of setColor that takes a predefined color (neccesary to allow const int pre-defined colors */void setColor(int* led, const byte* color){ byte tempByte[] = {color[0], color[1], color[2]}; setColor(led, tempByte);}/* Fades the LED from a start color to an end color at fadeSpeed led - (int array of three values defining the LEDs pins (led[0] = redPin, led[1] = greenPin, led[2] = bluePin)) startCcolor - (byte array of three values defing the start RGB color (startColor[0] = start Red value, startColor[1] = start Green value, startColor[2] = start Red value endCcolor - (byte array of three values defing the finished RGB color (endColor[0] = end Red value, endColor[1] = end Green value, endColor[2] = end Red value fadeSpeed - this is the delay in milliseconds between steps, defines the speed of the fade*/ void fadeToColor(int* led, byte* startColor, byte* endColor, int fadeSpeed){ int changeRed = endColor[0] - startColor[0]; //the difference in the two colors for the red channel int changeGreen = endColor[1] - startColor[1]; //the difference in the two colors for the green channel int changeBlue = endColor[2] - startColor[2]; //the difference in the two colors for the blue channel int steps = max(abs(changeRed),max(abs(changeGreen), abs(changeBlue))); //make the number of change steps the maximum channel change for(int i = 0 ; i < steps; i++){ //iterate for the channel with the maximum change byte newRed = startColor[0] + (i * changeRed / steps); //the newRed intensity dependant on the start intensity and the change determined above byte newGreen = startColor[1] + (i * changeGreen / steps); //the newGreen intensity byte newBlue = startColor[2] + (i * changeBlue / steps); //the newBlue intensity byte newColor[] = {newRed, newGreen, newBlue}; //Define an RGB color array for the new color setColor(led, newColor); //Set the LED to the calculated value delay(fadeSpeed); //Delay fadeSpeed milliseconds before going on to the next color } setColor(led, endColor); //The LED should be at the endColor but set to endColor to avoid rounding errors}/* A version of fadeToColor that takes predefined colors (neccesary to allow const int pre-defined colors */void fadeToColor(int* led, const byte* startColor, const byte* endColor, int fadeSpeed){ byte tempByte1[] = {startColor[0], startColor[1], startColor[2]}; byte tempByte2[] = {endColor[0], endColor[1], endColor[2]}; fadeToColor(led, tempByte1, tempByte2, fadeSpeed);}| « Previous Step | Download PDFView All Steps | Next Step » |
//--- bof RGBL - RGB Digital Preamble//
RGB LED pinsint ledDigitalOne[] = {14, 15, 16};
//the three digital pins of the first digital
LED 14 = redPin, 15 = greenPin, 16 = bluePinint ledDigitalTwo[] = {9, 10, 11};
LED 14 = redPin, 15 = greenPin, 16 = bluePinint ledDigitalThree[] = {3, 5, 6};
LED 14 = redPin, 15 = greenPin, 16 = bluePinconst boolean ON = LOW;
//Define on as LOW (this is because we use a common Anode RGB LED (common pin is connected to +5 volts)
const boolean OFF = HIGH;
//Define off as HIGH
//Predefined Colors
const boolean RED[] = {ON, OFF, OFF};
const boolean GREEN[] = {OFF, ON, OFF};
const boolean BLUE[] = {OFF, OFF, ON};
const boolean YELLOW[] = {ON, ON, OFF};
const boolean CYAN[] = {OFF, ON, ON};
const boolean MAGENTA[] = {ON, OFF, ON};
const boolean WHITE[] = {ON, ON, ON};
const boolean BLACK[] = {OFF, OFF, OFF};
//An Array that stores the predefined colors (allows us to later randomly display a color)
const boolean* COLORS[] = {RED, GREEN, BLUE, YELLOW, CYAN, MAGENTA, WHITE, BLACK};
//--- eof RGBL - RGB Digital Preamble
void setup(){
for(int i = 0; i < 3; i++) {
pinMode(ledDigitalOne[i], OUTPUT);
pinMode(ledDigitalTwo[i], OUTPUT);
pinMode(ledDigitalThree[i], OUTPUT);
void loop(){
/* Example - 1 Set a color Set the three LEDs to any predefined color*/
setColor(ledDigitalOne, RED);
//Set the color of LED one
setColor(ledDigitalTwo, GREEN);
//Set the color of LED two
setColor(ledDigitalThree, BLUE);
//Set the color of LED three
/* Exampe - 2 Go through Random Colors Set the LEDs to a random color*/
int rand = random(0, sizeof(COLORS) / 2);
//get a random number within the range of colors
setColor(ledDigitalOne, COLORS[rand]);
//Set the color of led one to a random color
//Set the color of LED 2 to a random color //
setColor(ledDigitalTwo, COLORS[rand]);
//Set the color of LED 3 to a random color //
setColor(ledDigitalThree, COLORS[rand]);
delay(1000);
/* Sets an led to any color led - a three element array defining the three color pins (led[0] = redPin, led[1] = greenPin, led[2] = bluePin) color - a three element boolean array (color[0] = red value (LOW = on, HIGH = off), color[1] = green value, color[2] =blue value)*/
void setColor(int* led, boolean* color){
digitalWrite(led[i], color[i]);
/* A version of setColor that allows for using const boolean colors*/
void setColor(int* led, const boolean* color) {
boolean tempColor[] = {color[0], color[1], color[2]};
setColor(led, tempColor);
Here's a link to the fixed, properly formatted code for the analog step:
http://pastebin.com/YwMXYH2i
