Step 5The code
The code for this project is pretty simple. The first part is for defing everything, the second for creating a random color, and the third for using the potentiometers and giving the pushbutton and leds commands.
Here it is:
/*Code for rgb led game shield. By Ikestarm17. Special thanks to Ladyada for
all the great products, mbeckler for his informational site, marklar, grumpy_mike,
and AWOL on the Arduino forums.*/
int greenled1 = 13;
int greenled2 = 8;
int greenled3 = 4;
int redled1 = 19;
int redled2 = 7;
int redled3 = 12; // leds that show if you were right or not
int buttonstate;
int val;
int val2;
int val3;
int switchpin = 2;
int switchpin2 = 0; // variables for the button stuff
int redactual;
int greenactual;
int blueactual; // variables for storing the colors you need to match
int redPin = 3;
int bluePin = 5;
int greenPin = 6; // pins for the rgb led you control
int redIn = 2;
int greenIn = 3;
int blueIn = 4; // pins for the potentiometers for the rgb led
int redguess;
int greenguess;
int blueguess; // variables to store the values of your led to compare to the random ones
/* This following part before "void setup()"
*is all about making the rgb led
*a "good" random color, not just a whited out one.
*I don't know much about this part,
*because I only changed one little part,
*Marklar from the arduino forums created it */
#ifndef RGBCommonLED_H
#define RGBCommonLED_H
#include "WProgram.h"
class RGBCommonLED {
public:
RGBCommonLED(int rpin, int gpin, int bpin);
~RGBCommonLED();
void setRGB(byte r, byte g, byte b);
void setHSV(byte h, byte s, byte v);
void setColor(unsigned long v);
void setHue(byte level);
void setSat(byte level);
void setVal(byte level);
void adjHue(int level);
void adjSat(int level);
void adjVal(int level);
void setRandomColor();
void setRandomHue();
void setRandomSat();
void setRandomVal();
void setHSVLevel(int section, byte level);
void adjHSVLevel(int section, int level);
void setRandomHSVLevel(int section);
void updateLED();
void HSVToRGB( unsigned int inHue, unsigned int inSaturation, unsigned int inValue,
unsigned int *oR, unsigned int *oG, unsigned int *oB );
void RGBToHSV( unsigned int inRed, unsigned int inGreen, unsigned int inBlue,
unsigned int *oH, unsigned int *oS, unsigned int *oV );
void updateHSVFromRGB();
int pins[3];
int rgb[3];
int hsv[3];
private:
boolean hsvSet;
void setRGBFromHSV();
void setHSVFromRGB();
#endif
RGBCommonLED::RGBCommonLED(int rpin, int gpin, int bpin){
pins[0] = rpin;
pins[1] = gpin;
pins[2] = bpin;
hsvSet = false;
RGBCommonLED::~RGBCommonLED(){
void RGBCommonLED::setColor(unsigned long v)
this->setRGB((v & 255),((v >> 8) & 255),(v >> 16) & 255);
void RGBCommonLED::setRGB(byte r, byte g, byte b){
rgb[0] = r;
rgb[1] = g;
rgb[2] = b;
hsvSet = false;
void RGBCommonLED::setHSV(byte h, byte s, byte v){
hsv[0] = h;
hsv[1] = s;
hsv[2] = v;
this->setRGBFromHSV();
hsvSet = true;
void RGBCommonLED::setHSVLevel(int section, byte level){
updateHSVFromRGB();
hsv[section] = level;
void RGBCommonLED::setHue(byte level){
this->setHSVLevel(0,level);
void RGBCommonLED::setSat(byte level){
this->setHSVLevel(1,level);
void RGBCommonLED::setVal(byte level){
this->setHSVLevel(2,level);
void RGBCommonLED::adjHSVLevel(int section, int level){
updateHSVFromRGB();
int th = hsv[section] + level;
if( th < 0 ){
th = 255 + th;
else if( th > 255 ) {
th = 255 - th;
th = constrain(th,0,255);
hsv[section] = th;
void RGBCommonLED::adjHue(int level){
this->adjHSVLevel(0,level);
void RGBCommonLED::adjSat(int level){
this->adjHSVLevel(1,level);
void RGBCommonLED::adjVal(int level){
this->adjHSVLevel(2,level);
void RGBCommonLED::RGBToHSV( unsigned int inRed, unsigned int inGreen, unsigned int inBlue,
double vals[3];
unsigned char maxc=0, minc=0;
double hue, sat, val;
vals[0]=inRed;
vals[1]=inGreen;
vals[2]=inBlue;
//red is set as maximum and minimum
if(vals[1]>vals[maxc]) maxc=1;
if(vals[2]>vals[maxc]) maxc=2;
if(vals[1]<vals[minc]) minc=1;
if(vals[2]<vals[minc]) minc=2;
val = vals[maxc];
if(vals[maxc]==0)
sat = hue = 0;
else
sat=255*(1-(vals[minc]/vals[maxc]));
hue = 60 * ((maxc*2) + (vals[(maxc+1)%3] - vals[(maxc+2)%3])/(vals[maxc] - vals[minc]));
if(hue < 0) hue += 360; //corrector for hues in -60 to 0 range
*oH = hue; //map(hue,0,360,0,255);
*oS = sat;
*oV = val;
void RGBCommonLED::HSVToRGB( unsigned int inHue, unsigned int inSaturation, unsigned int inValue,
if( inSaturation == 0 )
// achromatic (grey)
*oR = *oG = *oB = inValue;
else
unsigned int scaledHue = (inHue * 6);
unsigned int sector = scaledHue >> 8; // sector 0 to 5 around the color wheel
unsigned int offsetInSector = scaledHue - (sector << 8); // position within the sector
unsigned int p = (inValue * ( 255 - inSaturation )) >> 8;
unsigned int q = (inValue * ( 255 - ((inSaturation * offsetInSector) >> 8) )) >> 8;
unsigned int t = (inValue * ( 255 - ((inSaturation * ( 255 - offsetInSector )) >> 8) )) >> 8;
switch( sector ) {
case 0:
*oR = inValue;
*oG = t;
*oB = p;
break;
case 1:
*oR = q;
*oG = inValue;
*oB = p;
break;
case 2:
*oR = p;
*oG = inValue;
*oB = t;
break;
case 3:
*oR = p;
*oG = q;
*oB = inValue;
break;
case 4:
*oR = t;
*oG = p;
*oB = inValue;
break;
default: // case 5:
*oR = inValue;
*oG = p;
*oB = q;
break;
void RGBCommonLED::setRandomColor(){
this->setColor((unsigned long)random(0x01000000));
void RGBCommonLED::setRandomHue(){
this->setRandomHSVLevel(0);
void RGBCommonLED::setRandomSat(){
this->setRandomHSVLevel(1);
void RGBCommonLED::setRandomVal(){
this->setRandomHSVLevel(2);
void RGBCommonLED::setRandomHSVLevel(int section){
this->setHSVLevel(section, (unsigned int)random(0x0100));
void RGBCommonLED::updateHSVFromRGB(){
this->setHSVFromRGB();
hsvSet = true;
void RGBCommonLED::updateLED(){
analogWrite(this->pins[0], rgb[0]);
analogWrite(this->pins[1], rgb[1]);
analogWrite(this->pins[2], rgb[2]);
redactual = rgb[0];
greenactual = rgb[1];
blueactual = rgb[2];
void RGBCommonLED::setRGBFromHSV(){
unsigned int h = hsv[0];
unsigned int s = hsv[1];
unsigned int v = hsv[2];
unsigned int r = 0;
unsigned int g = 0;
unsigned int b = 0;
HSVToRGB(h,s,v,&r,&g,&b);
this->setRGB(r,g,b);
void RGBCommonLED::setHSVFromRGB(){
unsigned int r = rgb[0];
unsigned int g = rgb[1];
unsigned int b = rgb[2];
unsigned int h;
unsigned int s;
unsigned int v;
this->RGBToHSV(r,g,b,&h,&s,&v);
hsv[0] = map(h,0,360,0,255);
hsv[1] = s;
hsv[2] = v;
hsvSet = true;
RGBCommonLED led1(10,11,9);
void setup()
pinMode(redled1, OUTPUT);
pinMode(redled2, OUTPUT);
pinMode(redled3, OUTPUT);
pinMode(greenled1, OUTPUT);
pinMode(greenled2, OUTPUT);
pinMode(greenled3, OUTPUT);
pinMode(switchpin, INPUT);
pinMode(switchpin2, INPUT);// setting the leds as output and the switch as input
Serial.begin(9600); // start serial
randomSeed(analogRead(0)); // read analog pin 0 to get random value
led1.setRandomHue();
led1.setSat(255);
led1.setVal(255);
led1.setRandomColor();
led1.updateLED(); // set a random color on the first rgb led
buttonstate = digitalRead(switchpin); // read the switch as off
void loop(){
redguess = analogRead(redIn);
greenguess = analogRead(greenIn);
blueguess = analogRead(blueIn); // read the potentiometers
redguess = map(redguess, 0, 1023, 0, 255);
greenguess = map(greenguess, 0, 1023, 0, 255);
blueguess = map(blueguess, 0, 1023, 0, 255); // scale down the values
analogWrite(redPin, redguess);
analogWrite(greenPin, greenguess);
analogWrite(bluePin, blueguess); // set the color values
redguess = 255 - redguess;
blueguess = 255 - blueguess;
greenguess = 255 - greenguess; // fix the value's numbers so 0 is 255 and 255 is 0
val = digitalRead(switchpin);
delay(10);
val2 = digitalRead(switchpin);
val3 = digitalRead(switchpin2); // read switches and fix the bouncing
if(val3 == LOW && val == val2 && val != buttonstate && val == LOW && redactual + 55 < redguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && redactual - 55> redguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && blueactual + 55 < blueguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && blueactual - 55 > blueguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && greenactual + 55 < greenguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && greenactual - 55 > greenguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && redactual + 85 < redguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && redactual - 85 > redguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && blueactual + 85 < blueguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && blueactual - 85 > blueguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && greenactual + 85 < greenguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && greenactual - 85 > greenguess){ // make sure your led's colors do not match the other one's for the easier level
digitalWrite(greenled1, LOW), // turn on red leds
digitalWrite(redled1, HIGH),
delay(500),
digitalWrite(redled1, LOW),
digitalWrite(redled2, HIGH),
delay(500),
digitalWrite(redled2, LOW),
digitalWrite(redled3, HIGH),
delay(500),
digitalWrite(redled3,LOW);
delay(500),
delay(500),
delay(500),
digitalWrite(redled3,LOW),
delay(250),
digitalWrite(redled3, LOW),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250);
while(val3 == LOW && val == val2 && val != buttonstate && val == LOW && // make sure button is pressed
redactual + 55 >= redguess && redactual - 55 <= redguess &&
blueactual + 55 >= blueguess && blueactual - 55 <= blueguess &&
greenactual + 55 >= greenguess && greenactual - 55 <= greenguess ||
redactual + 85 >= redguess && redactual - 85 <= redguess &&
blueactual + 85 >= blueguess && blueactual - 85 <= blueguess &&
greenactual + 85 >= greenguess && greenactual - 85 <= greenguess){ // make sure your led's colors are close enough to the other one's for the easy level
digitalWrite(redled1,LOW), // turn on green leds
digitalWrite(greenled1, HIGH),
delay(500),
digitalWrite(greenled2, HIGH),
delay(500),
digitalWrite(greenled2, LOW),
digitalWrite(greenled3, HIGH),
delay(500),
digitalWrite(greenled3, LOW),
delay(500),
delay(500),
delay(500),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250);
Add Comment
