RGB flashing iPod dock from an old speaker!
 by gizzmotronics
Contest WinnerFeatured
Edit: I've entered in the LED contest, Hurricane Lasers, and Fix & improve it contest. If you like this, please vote.
Original Video - song: river of dreams by billy joel
Using an Apple Pro speaker, I made a flashing RGB LED iPod dock for about $35.
I recommend reading the entire 'ible before starting. Also, note that the volume is control from the iPod.
It consumes minimal power in shutdown mode, and is controlled by a Teensy.
This took me ~3 days to build, and you should know how to solder pretty well before doing this project.
The enclosure looks amazing when lit, it is really fun to watch it.
Step 1: Gather Tools & Materials
Tools:
Soldering Iron
Hot Air gun/Hair dryer
Hot glue gun/epoxy
Drill (or dremel)
Screwdriver
Sandpaper (fine grit)
Wire strippers
Parts:
(1) Teensy 2.0
(1) Sparkfun RGB LED breakout
(1) Sparkfun Mono Audio amp breakout
(1) Apple pro speaker (You only need one speaker, not the set)
(1) Mini-USB cable (will be cut up)
(1) iPod-USB cable (also will be cut)
(1) Audio plug
(1) Push-on/Push-off button
(1) 10K ohm resistor
(1) Roll of solder
(1) Headphone foam cover (black foam circles found on old headphones, I had a few lying around.)
Assorted heat shrink
Ribbon cable or other thin wire
Near373 says: Aug 20, 2012. 5:01 PM
Where can I a speaker to buy?
gizzmotronics (author) in reply to Near373Aug 20, 2012. 5:21 PM
it is discontinued, but you can get some on ebay.
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=apple+pro+speaker&_sacat=0
amandaghassaei says: Aug 20, 2012. 9:27 AM
cool so it reacts to the music? I'd love to see a video of it in action!
gizzmotronics (author) in reply to amandaghassaeiAug 20, 2012. 10:09 AM
I'll post one.
gizzmotronics (author) in reply to gizzmotronicsAug 20, 2012. 10:29 AM
posted.
amandaghassaei in reply to gizzmotronicsAug 20, 2012. 10:31 AM
nice! great project!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
