This i'ble is in constant update. If you're planning on doing something don't be afraid to drop a question.
I've always wanted a POV for my bicycle, specially a full colour POV capable of displaying text, images and small animations!
There are some cool POVs commercially available.
- SpokePOV from adafruit industries (and its i'ble)
- Monkeylectric's m132s
- Monkeylectric's recentely announced m464q
Unfortunately, the SpokePOV is only one colour, and the m132s, as I understand, doesn't have the ability to display images. Besides, I think these are a little too expensive for something that I will not use often.
So I though I would try to make my own with components I already had around. This way I don't have to spend any more money to try and play with a bicycle POV.
This project features:
- 16 RGB (Red+Green+Blue) Light Emitting Diodes;
- Arduino compatibility (Suposedely, I'll have to check that later);
- Single layer printed circuit board, suitable for home fab;
- All through hole componentes, suitable for beginners;
- Hall effect sensor, for image synchronization;
- Least number of componentes possible;
- Unfortunately, only one side of the wheel is illuminated (check update).
- Fits 26" wheels, I haven't had opportunity to try it in 20" and 24" wheels.
Update: I updated the board, so you can use only one board for lighting both sides of the wheel! But it won't work correctly in both sides for text...
Remove these ads by
Signing UpStep 1Before starting
- Solder electronics
- Make printed circuits boards
- Understand basic principles of electronics
- Know a little about microcontrollers
Tools
You'll need the basic tools to:
- Make PCB
- Work with and solder electronics
- Hardware and software to program the microcontroller
- 1x ATMega328p / ATMega168 microcontroller - ~4.3$
- 1x TLC5940 / TLC5941, 16 PWM Ouput LED driver - ~4.29$
- 16x Superflux common cathode RGB LEDs - ~13$
- 1x A3213 - 1.5$
- 3x PN2222, NPN transistors - cents
- Assorted resistors, capacitors, tact switches and connectors (check schematic and board layout) - another few cents
Download all the resources
Don't forget to download the schematic and board layout for Eagle CAD, and the source code for the firmware.
attention: TobyTetzi noticed that he download '.tmp' files instead of the .brd and .sch files. It also happened to me. I don't understand why.
I changed back to the original name and it seems to solve it.
rgb_pov_final.brd36 KB
rgb_pov_double_leds.sch278 KB
rgb_pov_final.sch275 KB
bike_pov.zip28 KB
POV_eagle_files.zip146 KB| « Previous Step | Download PDFView All Steps | Next Step » |
in order of keeping the image upright perhaps at any given speed. or to adjust image with speed.
Althought I have no idea how that would be accomplished :P
okay well an actual improvement might be....
having a contact on the wheel like a copper coated contact disk, so if its 3 wires 3 contact points near the axle (example would be just like slot cars) that way the led light could be the only thing attached to the spokes not big heavy battery packs... if that makes sense. I figure if you had the circuit board on the wheel an it lost contact for a half second it may reset the board or something so just the Led's should be alright.
Also, you are missing a vital point here.., you cannot simply extrapolate based on what you already know. For instance, at those speeds, it is possible that the inherent latency in the system would not allow for the display to refresh fast enough to display the image when you are going 60mph+ for example.
Also, you have no idea whether or not the hall effect sensor will be able to give you accurate reliable readings at those speeds.
I don't have Eagle.
Great! Thanks!
Thanks again!
I truly like to make POV as you did.
I already have AVR ATM8535. But I still don't understand the concept of using sensor in POV circuit. On your project what is the function of hall sensor and to what uC pin do feed it. Please email to: suwarnokaraba@gmail.com.
I am from Indonesia.
Please tell me what program you use to compose and generate color image file. Hex you register in microcontroller ATMega328p / ATMEGA168 microcontroller from RGBike POV project.
D. Sandu by comraex@yahoo.com
Thanks!
I want to mount these to the rim of a car wheel
Would the much high RPM's of the car rim cause problems?
Im not sure if the processor and hall sensor would be able to function fast enough to properly control the LEDs when the car is doing 30 mph or faster.
Maybe some how dividing the input variable of the hall by half would give the microprocessor more breathing room?
i know little about the microprocessor, would it be capable of keeping up with a car travelling 50 - 70 mph?
thanks!
any help would be highly appreciated
-Noah
There is a way to extract from the files! weee
use the exp-project-lbr.ulp
1. What are the values for R5-R7?
2. Can you use 2N2222 instead of PN2222?
JanD
2. You can, if the pinout is the same.
Yes, try to edit it in the rich editor, and see if it does work better
Hello Hazard,
I agree with the others, good project! It's clear that your experience extends well beyond this work, so whatever time you can spare here, I'm hoping to get your valuable input. If it's easier, bruce323g@gmail.com, USA 541-231-1101.
My niece and her boyfriend are doing this to learn some electronics, and I'm helping. This isn't 100% up-to-date but close: http://home.comcast.net/~bruce323/spokes/ . To keep costs low and to get low-level experience, they actually hand-wired onto a 100mil plated proto board that I had available. Lots of work, may turn out to have been a mistake, maybe next time we'll learn to do some etching at home, but anyway they're near hardware completion.
I'm sorry this is so long but I have the following ....(drum roll) ...
"TOP TEN LIST OF QUESTIONS ABOUT RGBIKE":
#10. Can we eliminate the JP3 RXD/TXD connector. Or if you used it productively, how; and is there any issue with it loading RST# at the wrong time and causing debugwire to fail.
#9. Briefly, what's the purpose for switches U$17 and U$24.
#8. For T1-3 we went with P-channel FETs, so we'll modify the code to invert drive polarity. But do you know, when the 328P comes out of reset, are its IO's (hopefully) still tri-state, or are they driven (I hope not low) until programmed otherwise.
#7. We're using 32 LEDs and two cascaded TLC drivers but we haven't analyzed processor bandwidth .... do you know whether your 16 LED design has much bandwidth to spare, or are we almost certainly hosed? We're running ATMega328 also at 20MHz.
#6. For U$18 we went with a crystal, and the external caps as shown on the schematic, but I'm nervous about mechanical, and from the .brd file it looks like you went with a resonator. Is the resonator tolerance adequate and are you inclined to think we should change to the resonator?
#5. When we bought the TLC parts, 5940's weren't available so we're using 5941's. Two differences I remember about 5941's: a) lower current drive, we'll deal with it; b) they don't have EEPROM for dot correction. Did you use the 5940 EEPROM for dot correction and would you expect we MIGHT see problems if we don't? Or maybe we'll make it happen with the 328P's EEPROM somehow.
#4. Do you have experience w/ how low a supply voltage your design can typically handle? (We're using 4 series NiMH's and we have more current load with our 32 LEDs).
#3. Your 16 LEDs are on 350 mil centers; our 32 LEDs (co-linear, same side of the board) are on 300 mil centers to fit the 100 mil proto board. How did you decide on the image's "aspect ratio", so to speak -- (1) distance between the LEDs, vs (2) rotational angle for updating the array. This may not be a clear question but if you have comments (are we hosed?), pls let us know.
#2. If we decided to go with your design as it is, would you ever consider supplying bare boards to folks like us for $$?
AND ....... (drum roll.... ) ...... the #1 question on the TOP TEN LIST ......... Yow, should we be paying you a consulting fee for all this?
Thanks for some or all answers!!!!
Hi! Sorry for the late reply. Here it goes
10 - Supposedly JP3 is pin compatible with FTDI usb-rs232 cable for using with the Arduino and bootloader. Never tried it myself.
I have never used debugwire. Check the datasheet for more information and typical schematic for using debugwire.
9 - Future expansions, like alternating between patterns and such.
8 - Detailed information can be found in the datasheet. Can't remember for sure from the top of my head.
7 - From my calculations when I did this project, I think we can connect 2 TLCs. But not much more :D
6 - I don't know if the crystal can be damaged. Other than that, you can use whatever :) Drift in frequency doesn't really matter in this application
5 - I did not use dot correction.
4 - How low? Depends on the TLC, the LEDs, and the voltage for the micro's running frequency. See the datasheets for the TLC and 328.
I bet it must be over 4V for the 328 to run at 20Mhz. (sometimes it can work with lower voltage than what they say)
3 - I am trying to understand the question..
I took no considerations on that matter :P But I think it worked just fine :D
2 - Sorry, but no. This project is a good exercise and works fine for a toy/hobby. But is not reliable for a final product.
1 - Yes please. Come buy me a beer or two, whenever you come to Portugal
Thanks very much!
About answer#2: I understand. We're sure not thinking of a product, we're just making one for our own use. I was only talking about 2 or 3 bare boards, so then we could make that many, but nothing like a product.
About answer#1: None of us in my family have ever been to Portugal, but it just so happens that my wife and son are going to Lisbon in a few weeks. If you wanted, you could send me your contact info in a Private Message, & they might treat you!
