RING OUT OF SPOON
1,374
24
Posted in WorkshopMetalworking
Introduction: RING OUT OF SPOON
About: Hello!! My name is PAWAN and I am 14 y/o.I like making simple and awesome things.Not a typical nerd nor a class topper,but surely gonna be a instructable Featured author.Follow me as I make awesome projects ...
Christmas ahead and everyone is thinking of the gifts,so what's better than a awesome and cheap ring.I made one for my friend as he always wears a plastic one in his thumb which is not that fancy than this custom made ring out of spoon.
Step 1: MATERIALS
TOOLS:
  • HAMMER
  • PLIER
  • CUTTER
MATERIALS;
  • Glass cleaner
  • Sandpaper
  • Stainless steel spoon
  • White toothpaste.
Step 2: CUT THE SPOON
First mark the areas to be cut with a marker.Then with using a cutter cut it.If you are having difficulty in cutting than you can also try to bend it and then break it from the marked area.
Step 3: BEND THE SPOON
Now this is a tough task. Remember that the spoon is of stainless steel so it won't be bend easily.To bend it I first bend it a little bit than using a kitchen gas I heated it up for easy bending.Use the plier for easy bending,if you have any type of circular steel object than it can help a lot.
Step 4: SANDING,POLISHING,PAINTING
Now first wash the ring with tap water.Once washed do it's sanding.After the sanding it done use the toothpaste or toothpowder to clean it and give it a shine.If you want you can do a coating of silver nail paint.
Step 5: WEAR IT
Wear it or gift it to someone on the christmas. QUICK TIP: if the finger of the person who you are giving this ring is small than you can use a glue gun and add a layer of glue under it.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
