These masks are based off of the Dragon Priest masks found in The Elder Scrolls V: Skyrim! I made them using a process called pepakura, for those who dont know what it is visit here: http://www.tamasoft.co.jp/pepakura-en/
You can google for just about any paper model there is, and if there isn't one already out there try to find the 3d file and unfold it in pepakura designer.
After you have the model printed, glue it tab for tab.
After that, buy some Bondo auto body filler, and Bondo Fiberglass resin, these chemicals will harden and make your pepakura feel like a finished product.
I mixed the bondo auto body filler and resin in about a ratio of 2-1, this makes the bondo much smoother, I used this mix to just slush around inside my mask (see pic). Sand down any rough edges, I used a mouse power sander, a dremel is more effective for those tight corners.
I used some craft foam for the detail on the forehead, just glued on with hot glue.
I painted it with spray paint, then used one of those cheap plastic brushes that come with a child's paint kit to texture the mask.
I then covered the inside of the mask with cotton velour, and put some foam under the velour to have it mold to your face a bit better.
All done! You can add straps or add horns or what ever you want!
Sorry i couldn't make a full picture tutorial, I didn't have enough pictures from start to finish of the project. Next time i make a pepakura i will take lots of photos!
brickblast says: Jul 11, 2012. 12:15 PM
try to add some red/blue/green/ecc... trasparent paint (or what you think is better) to add the "enchanted" effect. Still a nice work, well done !
Dusk Shadows says: Apr 28, 2012. 1:21 AM
you should put that in the contest you have a good chance of winning
dark clerick (author) in reply to Dusk ShadowsMay 7, 2012. 11:24 AM
Did, didn't win :P
Thanks though!
Dusk Shadows in reply to dark clerickMay 8, 2012. 8:03 AM
to bad i voted for you though if that makes you fell better
radio78 says: May 7, 2012. 5:47 PM
I don't know where this went wrong, looks like in the bondo sanding stage probably but the final product here is not good, friend. It's asymmetrical everywhere and just kind of banged up looking. I think you may have gone way too thick with the bondo and you lost the actual mask under it. Should try to use way less bondo, just enough to give it good structural integrity and smoothness for the finishing phases and paint.
dark clerick (author) in reply to radio78May 7, 2012. 11:23 AM
This was my first time using the 'Rondo' process where you mix resin and bondo and just slush it around inside actually. But yeah it is a bit asymmetrical, but geez i didn't think it was that bad... Thanks for the constructive criticism though.
I kinda like my skyrim projects to have a couple errors in them, it makes its what makes them art, and the ancient nord Dragon Priests wouldn't have had them look machine made either.
neckrochylde9 says: Apr 27, 2012. 7:45 PM
I would like to point out that Instructables is a tutorial site. Though i do think your mask is very nice, i don't think it's appropriate for you to just post pictures of it with one sentence describing your process and a link to the sale of the item on your Etsy store., as simply advertising is not what this site is geared for. Advertise all you like, but please do it with an actual tutorial. :)
cryptex says: Apr 14, 2012. 3:49 PM
the pepakura is alright but the finished job looks to uneven and rough it needs work sorry butconstructive critisism
Dusk Shadows says: Apr 13, 2012. 2:09 AM
WOW
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
