iImage Information
Hi all. i have been studying the vast collecion of minigun pics availible on the net, and the collection of knex miniguns. I believe this is and will be the 1st Knex Minigun instructable (not slideshow). I wanted to make it as realistic as possible, but realised that wasn't 100% possible. Actual Minigun barells are only connecred at one point, but with knex, you would need two points. I took this into account, and eventually decided to connect the handle and barell, which gave a firm base to add the main 'shell' of the gun. If your still reading this, you're probably getting bored. Let's get into pros and cons before ya' decide to just skip.....
PROS
Top handle
Angled back handle (comfortable)
Octapod... aka stand... (not tripod, is an octagon)
Shoots from a chain
Cons
Octapod pivot sometimes snaps (rarely, but happens)
Range varies
Ok. Were ready to start. This is a heck of a project!
Step 1Firing system
iImage Information
Building the 'boxy thing that goes on the side'
The chain puller basically...
and by the way, if you don't wanna be flagged as a noob, get a profile pic.
although you have scrapped it already, i was thinking you may be able to help
when i put in a chain loaded and everything, it only fire the first three or so shots before the chain comes off the gear
i removed the wheel and it helped a little bit, but did you eery have this problem when you had the gun?
If it's into the gun, the last couple of shots usually fall through without the motor's help because of the weight.
thanks for replying tho
wow, just asking for help then figuring out what was wrong after you replied, trying to help makes me feel terrible
well, thanks i guess
(i cant really say anything without seeming like a jerk)
it just falls off the gear, towards the front of the gun even when it is held out straight or supported by a table
i found that a slower motor actually helped, but not much
This is amazing!
Even though I don't have enough pieces to build it, If I did, I defiantly would make it!
I'll try to make a smaller version of it and post it.
5*
AWESOME GUN
