Introduction: R.O.B. Phone Notification Assistant
About: 3D printing and designing RaspberryPI projects for a few years now
Desktop Phone Notification Assistant Featuring (R.O.B.) Robotic Operating Buddy
Step 1: Flashing RaspberriPi Hard Disk / Install Required Software (Using Ubuntu Linux)
Create your new hard disk for DashboardPI
Insert the microSD to your computer via USB adapter and create the disk image using the dd command
Locate your inserted microSD card via the df -h command, unmount it and create the disk image with the disk copy dd command
$ df -h /dev/sdb1 7.4G 32K 7.4G 1% /media/XXX/1234-5678
$ umount /dev/sdb1
Caution: be sure the command is completely accurate, you can damage other disks with this command
if=location of RASPBIAN JESSIE LITE image file of=location of your microSD card
$ sudo dd bs=4M if=/path/to/raspbian-jessie-lite.img of=/dev/sdb (note: in this case, it's /dev/sdb, /dev/sdb1 was an existing factory partition on the microSD)
Setting up your RaspberriPi
Insert your new microSD card to the raspberrypi and power it on with a monitor connected to the HDMI port
Login
user: pi
pass: raspberry
Change your account password for security
sudo passwd pi
Enable RaspberriPi Advanced Options
sudo raspi-config
Choose:
1 Expand File System
9 Advanced Options
A2 Hostname change it to "RobbieAssistant"
A4 SSH Enable SSH Server
A7 I2C Enable i2c interface
Enable the English/US Keyboard
sudo nano /etc/default/keyboard
Change the following line: XKBLAYOUT="us"
Reboot PI for Keyboard layout changes / file system resizing to take effect
$ sudo shutdown -r now
Auto-Connect to your WiFi
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Add the following lines to have your raspberrypi automatically connect to your home WiFi (if your wireless network is named "linksys" for example, in the following example)
network={ ssid="linksys" psk="WIRELESS PASSWORD HERE" } Reboot PI to connect to WiFi network
Now that your PI is finally on the local network, you can login remotely to it via SSH. But first you need to get the IP address it currently has.
$ ifconfig Look for "inet addr: 192.168.XXX.XXX" in the following command's output for your PI's IP Address
Go to another machine and login to your raspberrypi via ssh
$ ssh pi@192.168.XXX.XXX
Start Installing required packages
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get install build-essential tk-dev libbz2-dev libexpat1-dev liblzma-dev zlib1g-dev libdb5.3-dev libgdbm-dev libsqlite3-dev libssl-dev libncurses5-dev libncursesw5-dev libreadline6-dev python3-pip python3-requests python3-setuptools python3-urllib python3-urllib3 python3-requests vim git python-smbus i2c-tools python-imaging python-smbus build-essential python-dev rpi.gpio python3 python3-pip vim git python-smbus i2c-tools python-imaging python-smbus build-essential python-dev rpi.gpio python3 python3-pip libi2c-dev vim git python-smbus i2c-tools python-imaging python-smbus build-essential python-dev rpi.gpio python3 python3-pip python-gpiozero python-psutil xz-utils
$ sudo pip install requests
Update local timezone settings
$ sudo dpkg-reconfigure tzdata
select your timezone using the interface
Setup the simple directory l command [optional]
vi ~/.bashrc
add the following line:
alias l='ls -lh'
source ~/.bashrc
Fix VIM default syntax highlighting [optional]
sudo vi /etc/vim/vimrc
uncomment the following line:
syntax on
make the logs folder for the application to run
mkdir /home/pi/RobbieAssistant/logs
chmod 777 /home/pi/RobbieAssistant/logs
Configure Application to run correctly in settings.py config file
Find the file settings-shadow.py in the /includes/ folder of the project and copy it to settings.py and adjust to your current settings
# forecast.io API key for local weather information
weatherAPIURL = 'https://api.forecast.io/forecast/'
weatherAPIKey = 'YOUR API KEY FOR FORECAST.IO'
# optional for running the remote temp/humidity logger
dashboardServer = 'mydevicelogger.com'
# search google to get the Latitude/Longitude for your home location
latitude = 41.4552578
longitude = -72.1665444
Step 2: Supplies Needed
RaspberriPi Zero
DHT11 Humidistat
LED Lights (x4) Green / Yellow / Blue / Red
2.6" Digole Display
Step 3: Build and Wire the Device
Prepare the Digole Display for i2C
On the back of the Digole Display, solder the jumper to assign the display to use the i2c protocol
Step 4: ​Using a 3d Printer, Print the Cover, Box and Back Panels
Using the following X STL files in the 3DPrint folder, R.O.B. Robot, LED Harness and Display Mount
buttonContainer-base.stl
buttonContainer-lid.stl
displaymount-final.stl
led-harness-final.stl
MiniNintendoROB.zip
Robot Print by: Mini Nintendo R.O.B. - by RabbitEngineering
https://www.thingiverse.com/thing:1494964
I used red tape to make the eyes red with the black visor background
Step 5: Component Wiring
Digole Display
GND -> GND
DATA -> SDA
CLK -> SCL
VCC -> 3V
DHT11 Humidistat
VCC -> 5V
GND -> GND
DATA -> GPIO 25
BLUE Resistor
VCC -> GPIO 17 (with 270ohm resistor)
GND -> GND
YELLOW Resistor
VCC -> GPIO 13 (with 270ohm resistor)
GND -> GND
GREEN Resistor
VCC -> GPIO 6 (with 270ohm resistor)
GND -> GND
RED Resistor
VCC -> GPIO 12 (with 270ohm resistor)
GND -> GND
RED Momentary Pushbutton
VCC -> GPIO 16 (with 270ohm resistor)
GND -> GND
BLUE Momentary Pushbutton
VCC -> GPIO 26 (with 270ohm resistor)
GND -> GND
Step 6: Connect Components to the Robot
After you've printed the screen holder, connect it to the digole display
Connect the Display to the RPi with enough wiring to glue the RPi to the back of the robot
Print the controller and wire the buttons with enough wiring to make it to the back of the robot
Finish Wiring and assembling the robot with the RPi connected to the back and the DHT11 glued to the bottom
Step 7: Check I2C Configuration
Start up your RaspberryPi and make sure the I2C bus recognizes all your connected 7/14 segment displays. [each display is given a unique address described above by how you solder each display's jumpers in different combinations]
If you have the display with jumper soldered correctly, you should have the following output for the i2cdetect command:
sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- 27 -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Step 8: DHT11 Install
$ cd ~
$ git clone https://github.com/adafruit/Adafruit_Python_DHT.g...
$ cd Adafruit_Python_DHT/
$ sudo python setup.py install
$ sudo python ez_setup.py
$ cd examples/
$ vi simpletest.py
sensor = Adafruit_DHT.DHT11
Comment the line out
pin = 'P8_11'
Uncomment the line and change the pin number to 16
pin = 25
Run the test
python simpletest.py
You should see a metric reading of Temp and Humidity displayed on the command line.
Step 9: Clone Repository
$ cd ~
$ git clone https://github.com/khinds10/RobbieAssistant.git
Step 10: Add Pushbullet API (using Python 3.5)
Using the pushbullet app for your phone, signup to recieve an API key to have a simple python script be able to capture and push data hub notifications and indicator flags
Install Python 3.5 for asyncio functionality
$ sudo apt-get update sudo apt-get install build-essential tk-dev sudo apt-get install libncurses5-dev libncursesw5-dev libreadline6-dev sudo apt-get install libdb5.3-dev libgdbm-dev libsqlite3-dev libssl-dev sudo apt-get install libbz2-dev libexpat1-dev liblzma-dev zlib1g-dev If one of the packages cannot be found, try a newer version number (e.g. libdb5.4-dev instead of libdb5.3-dev).
$ wget https://www.python.org/ftp/python/3.5.2/Python-3.... tar zxvf Python-3.5.2.tgz cd Python-3.5.2 ./configure --prefix=/usr/local/opt/python-3.5.2 make sudo make install sudo ln -s /usr/local/opt/python-3.5.2/bin/pydoc3.5 /usr/bin/pydoc3.5 sudo ln -s /usr/local/opt/python-3.5.2/bin/python3.5 /usr/bin/python3.5 sudo ln -s /usr/local/opt/python-3.5.2/bin/python3.5m /usr/bin/python3.5m sudo ln -s /usr/local/opt/python-3.5.2/bin/pyvenv-3.5 /usr/bin/pyvenv-3.5 sudo ln -s /usr/local/opt/python-3.5.2/bin/pip3.5 /usr/bin/pip3.5 cd ~ echo 'alias python35="/usr/local/opt/python-3.5.2/bin/python3.5"' >> .bashrc echo 'alias idle35="/usr/local/opt/python-3.5.2/bin/python3.5"' >> .bashrc Install the python3 dependancies
$ sudo apt-get install python3-setuptools sudo apt-get install python3-pip sudo pip3 install asyncpushbullet sudo pip3 install requests Optional way Download the python repository directly to obtain the python dependancies without the use of pip installing it
git clone https://github.com/rharder/asyncpushbullet
cd asyncpushbullet && sudo /usr/local/opt/python-3.5.2/bin/python3.5 setup.py install
Visit the pushbullet settings page in your account to generate an API key to use https://github.com/rharder/asyncpushbullet
Configure your pushbullet-listener.py script to have the correct API and dashboard central host
# your API Key from PushBullet.com
API_KEY = "o.XXXYYYZZZ111222333444555666"
# dashboard central server host
dashboardServer = 'MY-SERVER-HERE.com'
Step 11: ​Add the Script to Start at Dashboard Boot and Restart Your Dashboard Pi
$ crontab -e
@reboot nohup /usr/local/opt/python-3.5.2/bin/python3.5 /home/pi/PushBullet/pushbullet-listener.py >/dev/null 2>&1
@reboot nohup /usr/local/opt/python-3.5.3/bin/python3.5 /home/pi/RobbieAssistant/PushBullet/pushbullet-listener.py > /dev/null 2>&1
@reboot nohup python /home/pi/RobbieAssistant/Robbie.py > /dev/null 2>&1
@reboot nohup python /home/pi/RobbieAssistant/Temp.py > /dev/null 2>&1
@reboot nohup python /home/pi/RobbieAssistant/Weather.py > /dev/null 2>&1
Step 12: OPTIONAL: Creating Your Own Nintendo Images to Render on the Display
Upload your own 128x128 file to the following URL:
http://www.digole.com/tools/PicturetoC_Hex_converter.php
Choose your image file to upload, add what size you want it to be on the screen (Width/Height)
Select "256 Color for Color OLED/LCD(1 byte/pixel)" in the "Used for" dropdown
Obtain the hex output.
Add the hex output to a display/build/ header (.h) file, use the other ones as guides for syntax.
Include the new file in the digole.c file #include "myimage.h
Include a new command line hook to your image file in the. Note: the command below is saying draw your image at position 10 pixels over 10 pixels down. You can change it to different X,Y coordinates, you can also change the values 128,128 to whatever size your new image actually is.
} else if (strcmp(digoleCommand, "myimage") == 0) { drawBitmap256(10, 10, 128, 128, &myimageVariableHere,0); // myimageVariableHere is defined in your (.h) file }
Now rebuild (ignore the errors) below to have your new image render with the following command.
$ ./digole myimage
Re-Building [Included] Digole Display Driver for your optional changes
$ cd display/build
$ gcc digole.c
$ mv a.out ../../digole
$ chmod +x ../../digole
Step 13: Finished!
You're finished!
