ROBLOX - Self Homming Firework Launcher
5,293
9
16
Posted
Introduction: ROBLOX - Self Homming Firework Launcher
In the game do you wish you had 100% accuracy? Well with this launcher you will and all you need is a couple of bricks, a firework, and a security camera. They can be obtained from a free model. Its a one time use unless you drag another firework into the barrel. NOTE: This is a highly dangerous weapon and there is no need to supe up to a nuke-rocket, regular fireworks work fine!
Step 1: Parts for the Barrel
All parts seen here are...
-unanchored
-held together with welds
-material = plastic
You need to build these parts to fit the type and size rocket you are using so the base of mine is a 8x8 plate and the walls are about 15 - 20 units high.
The little door in the wider wall is so that you can light the fuse... duh
formula for parts: length x width x hight
Step 2: Building the Barrel
1) add the wider wall to one end on the square
2)add the 2 less wide walls on oposite ends
3)add the wide wall with the opening on the last side and group the whole thing
the barrel is done and you can now paint it however you like.
Step 3: Parts for Stand
all parts shown are unanchored except the dark grey base.
Step 4: Building the Stand
1) add the 6x6 brick in the center of the dark grey hinged base
2)add the 4x2x2 brick onto the 6x6 brick like so
3)add the 2 tall 2x1's onto the previous brick like so
4)add the 2 hinged bricks facing eachother like so
5,6)remove one side and add a 10x2x1 brick onto one hinge
7)replace the hinge and brick like so...
Time to combine the two!
Step 5: Finishing Touches
1)add the barrel with the opening facing up onto the black brick like so...
then group the whole thing
PARTS:
You will need the seat and a homming security camera
2)add the seat next to the opening so you can sit there
3)weld the camera to the front like so for maximum accuracy and group it to model
Step 6: Loading and Firing
load firework by dragging it into the barrel and fire it by clicking the fuse. NOTE: you dont have to be sitting on it to fire. Have fun and get some KO
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    16 Comments
    Could you post links to the exact parts you used? It wouldn't work for me.
    I am gonna add a Script to this to where it automatically shoots and reloads when a person except the owner comes to close. I am also going to make it compact so it can be hidden. Not to mention it can shoot through walls to chase you, then once it touches the Humanoid, KABLOOY
    hey it's my two favorite websites instructables and roblox
    why not make a regen for the firework. just group the regen for the model with the firework too
    man  where did you get that firework ?!   or where did ya get that ammo for your cannon ?
    but does it actually home in onanything?
    the consept of this is that the firework would be shot after aimed at a torso within 100 studs, the action is scripted so that it will shoot.
