ROBOT CHICKENS Awesome Bolt Action Knex Gun.***
4,741
Published
Introduction: ROBOT CHICKENS Awesome Bolt Action Knex Gun.***
probably the easyiest to build bolt action gun there is on instructables.its pretty powerful and its so easy its bulit in five easy parts. it also has the ability to fire upside down. By the way this is my first instructable, so don't be so harsh on it.
if you cant undersand any instructions post and say so and ill try and sort it.
I TAKE NO RESPONSABLITY FOR WHAT HAPPENS USING THIS GUN!
Step 1: Magazine
lets start easy... (pic 1) make two of each.
(pic 2) clip together as shown.
(pic 3) completed.
SIMPLE!
Step 2: Barrel
once again very easy. there are only 2 grey rods. i aplogise for using 13 tan clips, but they help the gun function better. they grey connectors are half moon ones.
this part uses...
13 tan clips
12 Y clips
13 half moons (yellow/gray)
2 full circle connectors
2 orange connectors
2 gray rods
1 red rod.
(not so) SIMPLE!
Step 3: Ram Rod
u need tape, any tape will do, because otherwise the ram rod breaks.
black rods are best but if you dont use a gray one.
Step 4: Recommended***
this is just so that the bullets dont fly out of the mag, and so you can shoot upside down. you only need one.
now to put it all together.
Step 5: Put It All Together
just follow the pictures.... simple.
NOTE: pic 4 the magazine has the part made in step 4 inserted, make sure you use a weak rubberband or you'll end up jamming the gun frequently.
Step 6: Loading and Firing
no you've completed my knex gun you need to know how to fire it...
pleeze post your comments and rate.
Step 7: Mods for My Gun
i have come up with some ideas you could try, if you want to...
1) add white circle connectors each side of the magazine with yellow rods on, so you can use upside down holding the mag.
2) if you want add a block trigger, or if you can make one a true trigger.
3)add a handel, but i would say only if you add a trigger, because otherwise when you pull back the piring pin the handel moves and breaks off.( the idea being if you hold the gun wilst pulling back the ram)
    • Pets Challenge
      Pets Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    40 Comments
    "my camera has a mirror image effect, im right handed."
    Don't insert a comma! Use the power of the one and only Semicolon!
    ...and punctuation...
    what does bolt action meen
    late peply but bolt action is use on snipers, where they pull it back to reload the bulet
    nope, you pulll back, and push forward
    nopem you pull back, puch forward, pull the trigger
    Check OUT this roller coaster. I made one like this, but it only 14 feet tall.
    not to be rude, but did you get any weird looks from neighbors?!?!?!?!?!?!?!?!?!?!?!?!?!?!
    Is it the same thing as a 2 sided orange connector? or different?
    its the same. a little late lol
    i like the small simple guns. however this rocks dude. ps. i cant watch robot chicken. he he.
    how do you make a NEW COOL true trigger????
    it looks cooler if you place the loader under the gun and the elastic band will put them it
