Introduction: ROV Thruster 10,5 Lbs From DT700 Brushless Motor
If you are going to build an underwater robot (ROV) then the first question is the choice of the thruster. Having a good thrust you can lift heavy loads, work in current and install additional equipment. If your thruster has high efficiency you can use even a small battery and the running time will be great. But where to get such a thruster?
You can made high-efficient thruster with superior performance from an inexpensive but very popular DT700 brushless motor. It will be more efficient and powerfull than Blue Robotics T200!
Step 1: Items
1. DT700 hexTronik brushless motor from Amazon or eBay - $14.4
2. Kort nozzle set - $30 (and now on Amazon)
3. An epoxy resin - $4
Step 2:
Step 3: Preparing DT700 Wires for Underwater
You should prepare DT700 for it. Although most brushless motors can work in water, it is recommended to make some modifications. Over time (after 100-1000 hours) microscopic damage appears on the wire's protective coating. Leakage of current through these holes can lead to malfunctions in the ESC or RC controllers. Moreover electric current into these holes causes electrochemical corrosion, which leads to a rapid destruction of the wires (after 10-100 hours). To prevent this we should impregnate the wires with epoxy. The engine will operate underwater with increased power so it is necessary to ensure a good heat dissipation. To do this, choose an epoxy with a high thermal conductivity.
At first we used Thermally Conductive Potting Compounds only, like this one but this summer we tested few types of inexpensive epoxy, like this and find them perfect. Ideally, you should use a vacuum chamber to remove air, but even without it we get a fairly stable result. The basic requirement for an epoxy is that it must be sufficiently liquid to have time to fill the space between the wires. If there is air left it can lead the motor to overheat at maximum load.
Step 4: Additional Preparations
If you will use thruster at high power you should prepare DT700 for it too. Our test show this two small screws can not keep the motor from turning at maximum load. Even if you screw them hard they will not be able to hold the shuft securely and leave only shallow scratches. This can lead to a break in the wires and damage to the motor. I recommend you to drill a sink as on the photo. This completes the preparation.
Step 5: Assembling the Thruster
1. Put the ring on the motor shaft so that the mounting holes match each other.
2. Insert the ring into the Kort nozzle and tighten with three screws.
3. Insert the motor wires into the nozzle holes
4. Insert the motor into the nozzle until it stops.
5. Secure the motor with the supplied hex wrench.
6. Install the left or right propeller and fix it with the supplied nut.
The thruster is ready!
Step 6: Our Test Result
Within a year we use these thrusters on our ROV and there have never been any failures. The propellers have never broken, despite the large number of algae in our lakes. Thrusters consume little energy but give a lot of thrust so we use batteries on board and it lasts for 5-8 hours of continuous operation. Our last test showed a record thrust of 10.5 pounds (4,78 kg) at 12 volts 25 amps and it's more than Blue Robotics! We also measured the efficiency of the thruster. At a current of 1 amp it is an incredible 52 grams per watt (1.83 ounces per watt) and it's also more than Blue Robotics!
It's one of the best DIY thruster for ROV MATE. With such efficiency and thrust you can make a powerful underwater robot, suitable for professional work.
Make an instructable with our thruster and permanent link to this article and get 2 (two) Kort nozzles for free!
DIYunderwater made it!
1 Questions
Hello. I am new to Instructables. I purchased 2 of your thrusters and the DT700 motors. I will be using them to propel my kayak (hopefully). I will not need remote control since I will always be sitting in the kayak when I use the thrusters. Can you recommend a speed controller that can be purchased in the U.S?
Also, since I will not be using any remote option on the speed controller, how can I control the amps sent to the motors? I would like to control this with a knob or something similar.
Many Thanks
I now have all of the components available for assembly. (Hobbypower 60A-SL ESC) Can I use a 12v battery or do I need 11.1 volts as recommended for the DT700 motors.
Hello. As I can see this one suitable:
https://www.amazon.com/dp/B071777MG2/ref=psdc_2234...
You can connect two motors to this one ESC.
It has forward/reverse function but some of them cannot 100% reverse and usually the most of functions closed and you have to buy a program card to open. So you should ask seller about.
All of ESC can be operated with an ESC tester any one suitable:
https://www.amazon.com/GoolRC-Tester-Consistency-H...
https://www.amazon.com/RCmall-Digital-Consistency-...
https://www.amazon.com/Hobbymate-HBS100-Voltage-di...
Besr regards.
9 Comments
Will this work to power a diy fishing torpedo? Can I use a lipo jumper battery rather than the SLA battery? Do you have any other information that may help me with a fishing torpedo project?
Yes, it will be perfect for a fishing torpedo and of course you can use a lipo battery.
We can help you with design and calculation. What thrust you need?
Loved the design! Voted!
Really cool instructable! I love the design!
Nice! Do you plan to share your 3D thruster model designs too?
We worked on the Kort nozzle design for a year and built about 50
different variants before we made it better level efficiency than the
Blue Robotics T200. Perhaps we can do something new and then publish the file of the first model, but for now we would like to get at least a
small return from it. I hope that price seems reasonable for the amount
of times it take to 3D print one and given that
this is our design and our work. At the same time we can send this Kort
nozzle for free to someone who made an instructable with our motor.
Would a lighter, but substantially prop an nozzle assembly yield better results? Im doing sone testing with an hp fusion jet and I would love to print one for you to try.
We will be happy to test every props you made with photo, video and chart results. I think it cannot be better but who knows:)
Very cool. I can't wait to see what cool projects that you could make with these motors.
