Step 16Finishing off
(putting it togethet and closing up)
---Put some hot glue around the LED's and press them into the holes in the reflector plate. Make sure that you dont get any glue on the tops of the LED's. And let it dry.
--- Now clip off the unecessary corners of the triangular PCB, so that it fits into the tube(pipe).
---Arrange the battery inside the pipe. Put a rubber washer between the rim of the pipe and the plexiglass disc. Now fit everything inside, and screw the cap on.
You'll have to open the front window to turn the light on and off.
---Later im considering adding a light resistor to the circuit so that it turns on and off depending on the light conditions.
Add Comment
