3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ROV submersible (PVC)
Step 18ROV update
ROV update
Here are a few things i have done to the ROV in the last week.
-Added a frame to the top/bottom (top in the water, bottom on land)
-Bought a sealed lead-acid 12V battery (it came withought a charger, anyone know how i could charge it?)
-Made some havy PVC weights (pvc pipes with metal in them) to strap to the bottom of the ROV for buoyancy ballance
-Bought some relays (turned out to be the wrong kind) and 3 way switches to make a control box.
-Made the control box (pic's are coming soon)
-And this saturday i'm going to do the maiden vayage in my friends' pool..video's will be coming :D
3 comments
Oct 24, 2009. 2:55 PMivorandjuan says:
 hi if you have an old security system that is no longer in use you can use that as this type and size of battery is the standard security system backup battery if you don't have the security system the voltage required is 13.6v dc at 1 amp but you will have to set a timer for the same amount of hours as the amphr as the battery ie: 7ah =7 hrs 6.5ah =6.5 hrs etc etc
Oct 24, 2009. 2:59 PMivorandjuan says:
 be careful not to overheat the battery as that will dry out the gel cells inside and the battery dies then it still has one use left (holding the door open on hot days)
Jun 22, 2009. 10:42 PMneelfamily says:
If you have not found a charge you should look for a car battery charger. There has to be one that can charge that battery or every maybe a charger for a power wheel chair might work, it might not turn off on its own like a car charger would.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:daniel2008
