Step 19ROV test in pool
And it was awesome!!
Never expected that 6 months of work would give me such a good result.
Well here are the pics, and the video both from onboard the ROV, from the surface and from my underwater camera.
;) enjoy
thanks,
Daniel
the pumps are bilge pumps and go for between 10 and 50$ online (ebay).
i used ?pantry pumps? since i couldn't get bilge pumps.
keep me posted on how it goes and i'm happy to answer any questions you may have about the build.
Dan
I have had another idea, i could get a 'tee' piece of pvc pipe and cap it off at each end, then use one of those little 3 volt hobby motors, drill a hole about the size of the shaft in one of the ends, and poke the shaft through, then fill it with epoxy.
That way it would be waterproof and i would be able to connect it to the main frame ROV! now i just need to get a few props.
BTW; what size pvc pipe did you use since i will need to get it so the motor will fit inside.
Daniel :)
The pvc pipe diameter is 2.5cm i believe.
Thanks again!
btw did you use bllast system here?
making a propeller is neither easy or cheap so it's probably best if you buy them online or at a hobby store .
The rov is neutrally buoyant. The thruster (vertical) ensure the movement up or down
