3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RS-232 Infrared Receiver in a Serial Connector (LIRC) Computer Remote Control
Step 3Circuit Walkthrough
Circuit Walkthrough
First of all, I'm going to try to avoid telling you to solder pin1 to pin2, and give you more english directions. The problem with this is that english is ambiguous, just ask any computer scientist : )
The only component I will refer to by pins is the 9-pin serial connector because I gave you a pretty diagram in the last step so everyone should be able to figure that out.
So, in order to try to make the english explanation less ambiguous I'm going to set out a few rules.
1) I will say that a component is 'on its back' which will mean the following:
a) The IR receiver is 'on its back' when the rounded receiver side is up and the flat side is down.
b) The voltage regulator is 'on its back' when the totally flat side is down and the two level side with printed letters is up.
Here we go:
1) Solder the dark side of the diode to pin7 (RTS) on the serial connector, that is the stripe indicating direction will be on the opposite side of the diode from the serial connector.
2) Solder the striped end of the diode to the center pin of the 7805 voltage regulator
3) Solder pin 1 on the serial connector to the resistor.
4) Solder the other end of the resistor to the left-hand pin on the 7805 voltage regulator assuming the voltage regulator is -on its back-
5) Solder pin 1 on the serial connector (where we just connected the resistor) to the right-hand pin on the TSOP1138 IR receiver, assuming the receiver is -on its back.-
6) Solder pin 5 on the serial connector to the negative side of the capacitor
7) Solder the positive side of the capacitor to the center pin of the TSOP1138.
8) Solder pin 5 on the serial connector (where we just connected the negative side of the capacitor) to the left-hand pin of the TSOP1138 (assuming its on its back)
9) Solder the center pin of the TSOP1138 (where we just connected the capacitor) to the right-hand pin of the 7805 voltage regulator, assuming the voltage regulator is -on its back-
Keep in mind that several points will have multiple connections. For example, the center pin of the TSOP1138 connects to the positive side of the capacitor as well as the right-hand pin of the 7805 voltage regulator, assuming the voltage regulator is -on its back-
Okay... so that's really, really nasty and I would never figure how to build a circuit like that... but perhaps it will help someone who doesn't read circuit diagrams very well.
9 comments
Oct 24, 2010. 5:14 AMtajmohd15 says:
Hi,
which remote control should be used to this RS-232 Infrared Receiver in a Serial Connector (LIRC) Computer Remote Control.
is it a universal Infrared Receiver
please reply me
Oct 28, 2010. 8:49 AMtajmohd15 says:
can u please tell me how to make in usb version
Nov 21, 2010. 12:04 AMtajmohd15 says:
in usb Cant we connect
DCD to red wire
RTS to white or Green wire
GND to Black wire
Nov 16, 2010. 8:28 AMtajmohd15 says:
DCD to red wire
GND to Black wire
Aug 7, 2008. 5:10 AMinfraredman21 says:
Well, hello there i'm Chris i'm a big computer junky my self but the only computer that has that seral port is very old my new computer only has usb, now do you thing we could make one thats a USB??
Aug 31, 2010. 11:21 AMdleite says:
You could do a USB one from scratch, ( I was able to get my XBOX DVD Remote to connect to Linux via LIRC). A simple solution may be a USB to Serial device and driver.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:darc
Just a geek with a soldering iron...
