3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RSS Desktop
Step 3Use Feed2JS to create HTML feeds
Now, you find the feeds that you want from all over the web and go to: http://jade.mcli.dist.maricopa.edu/feed/index.php?s=build
Place the URL of the feed(like the instructables feed at http://www.instructables.com/ex/y/process/rss.xml) into the form and set it up the way you want it. There are a lot of different options so be sure to use the preview feed button until you have it the way you want it.
Once you are happy with it, simply click on the Generate JavaScript button and cut and paste the code it generates into your html for the individual cells in your table.
It will look like this (<script language="JavaScript" src="http://jade.mcli.dist.maricopa.edu/feed/feed2js.php?src=http%3A%2F%2Fwww.instructables.com%2Fex%2Fy%2Fprocess%2Frss.xml&chan=title&num=4&date=y&targ=y" type="text/javascript"></script>)
2 comments
Feb 9, 2011. 11:13 PMza-experimenter says:
The address you give is not valid anymore. Like JayDugger says, try feed2js.
The exact new address for what you want is;
http://feed2js.org/index.php?s=build.
Jul 6, 2007. 10:49 PMJayDugger says:
Try using http://feed2js.org/ instead of the link given.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Toshibi
