Introduction: Rack for Small Storage/Display
Storage/Display-Rack:
When you start the display rack make sure you have:
Long Board,
Thin Ply-Wood,
Table Saw,
LETS START!
Step 1: Cutting the Board to the Accustom Length.
STEP 1:
When you start take the board and cut it to the length of how big you would like the display to be.
Step 2: Cutting the Slits Into the Wood.
Using the table saw cut into the wood small slivers only thick enough to barely fit the thin plywood into.(needs to be tight fit unless you like to use glue). Make sure you measure the height of the object your displaying so you can cut the slits far enough from each other to fit.
**Remember** Measure twice, cut once.
Step 3: Making the Plywood Sqaures
Using the thin plywood cut it to the size wanted.(refer to the picture above). these will be going into the slits of he wood, so make sure you don't make it to big or make it too small.
Step 4: (Optional) Spray Paint.
Spray paint if wanted to the color of your desire.
Step 5: Install the Display
Nail it into the wanted spot and put on your objects for display!
Please comment on instructions and how it worked for you! Thanks!
