iImage Information
I grew up long after vacuum tubes had stopped being used, but I always found technology from that area to be fascinating. Nixie tubes in particular I think are very cool. They are filled with neon gas, and work by accelerating electrons from the digits to the grid in the front. You actually get a gradient of different colored plasma as the electrons gain velocity; the layer nearest the digits is a light orange, while the next layer is blue. I suspect that if you looked at running nixie tubes over a wide-spectrum camera that can view ultraviolet and infrared they would look very cool. But I digress. I have seen plenty of nixie tube clocks around, and I thought it would be cool to make my own. I used six IN-12B nixie tubes from ebay with six vintage russian high-voltage driver ICs (to the best of my knowledge there is no modern equivalent of this IC). To run it all, I used a preprogrammed driver microcontroller from AllSpectrum Electronics. I considered programming an Arduino to run the clock functions, by the microcontroller AllSpectrum sells is far more advanced than anything I could program in a reasonable timeframe. I designed an acrylic case to have a unique aesthetic that I think separates my clock from most others that you can find on the internet. I then used a laser cutter to cut out the case, and glued it all together. The tube orientation I used is a bit weird because I didn't want any tubes upside down. In the picture below, the time is 12:03:00. The lit numbers are much clearer in person, it is difficult to capture the way they look on camera, but I tried my best.
Step 1Parts
iImage Information
You'll need the following stuff:
Six IN-12A or IN-12B nixie tubes (The only difference is the side the decimal point is on) (eBay)
Six IN-12 nixie tube sockets (eBay)
Six 74141 high voltage nixie tube driver ICs (eBay)
A high-voltage supply circuit (around 170 Volts)
Two 1/4"X12"X12" sheets of plastic (or whatever material you need for your own case design) (Mcmaster-Carr)
Two normally open pushbuttons (eBay)
A 6-digit nixie tube clock controller IC (www.allspectrum.com)
Various resistors, capacitors, and supercapacitors as called for in the datasheet for the controller IC
A temperature-compensated crystal oscillator (TCXO) or a regular crystal (I got a free sample of a TCXO from maxim-ic.com)
Neon bulbs (if you want delineating colons and and am/pm indicator, I skipped them)
A circuit board (I used one with copper pads on the bottom to make it easier to solder on components) (futurlec.com)
An epoxy capable of gluing plastic
you act like everybody have the stuff lying around
