Step 3: Electrical stuffs
For the light i removed the 9 led array board from a flashlight and de-soldered the white diodes replacing them with UV leds from eBay. These diodes are cheap, offer no filtering and deliver lots of harmful UV in one direction. Don't look into them or point at your friends eyes. Do check out suspicious stains on their clothes. I was able to salvage the on/off witch from this flashlight, i think i will use it someplace during the build. Start thinking of places to mount it.
The place I want to mount the laser is cramped by the A/B buttons. I'm going to have to remove most of the metal shell from the laser pointer to make it fit; doing this will allow me access to the on/off switch as well. Relocating this switch to the trigger assembly will make this gun much more realistic. Every time the trigger is pulled there will be an audible click and visible red dot on the target. It lends this project some sense of respectability.
After locating the laser switch, bypass it with a wire just behind the diodes single resister. Now you can use any switch to turn the laser on, not just the one it came with. At this point I'd like to mention this laser ran off three 1.5v button cells. I'm going to use three 1.5v AAA batteries to power it from now on. Button cells are expensive and a pain to find, your better off with cheap, easy to locate AAAs for longer life and fewer battery changes. Care should be taken to supply correct voltage to your diode, my LED array and laser just happen to both run on 4.5v. Lucky me.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
