Radio Arduino Simple
4,133
33
15
Posted
Introduction: Radio Arduino Simple
Hello,
Ok, before to introduce this project, i want to apologize for my English, my native language is French...
Secondly, this is my first Instructable, and it's the first part of a biggest project (a MP3/SD card/USB/radio/bluetooth/clock/alarmclock/temperature/humidity on TFT touchscreen 3.5")
So, I was searching for a tutorial to create a simple Radio with Arduino... And all what I found was very complex sketches for a very simple result, and I didn't find any tutorials to use it with a TFT and UTFT library.
I decide to create a tutorial for noobs like me which are searching for it.
First , The goods :
- Arduino MEGA2560 compatible (ready for the next steps of the project)
- 2.2" TFT ILI9225 controller
- TEA5767 breakout board
- 1 button
- 1 resistor 10k
- 1 step up module (from battery 3.7v to 5v)
- 1 battery (here i took a battery from an old tablet 3.7v, 6000mAh)
- Speakers (i used old computer speaker with integrated amplifier for the test)
- Wires and breadboard
- Arduino IDE for the sketch
Step 1: Let's Go for Wiring
Please be cautious, and wire the battery only when everything is finished !
TFT 2.2"
VCC : +5v
GND : GND
SDI : D51
CLK : D52
CS : D22
RST : D30
RS : D24
TEA5767
VCC : +5v
GND : GND
SCL : 21(SCL)
SDA : 20(SDA)
Button
Resistor 10k on ground
Don't forget to link the GND wires from TFT and TEA5767 with Arduino GND
Step 2: How Does It Work ?
Remember I said a simple radio !
I should say VERY simple !
I'm using only the same 10 stations, then, I'm not interrested in a radio which scans all the frequencies, is very complicated to use,...
Here, in the sketch you write the different frequencies you want, and the button just changes the stations.
I think I can't make more simple :-)
The libraries :
You'll need 4 libraries :
Wire.h (included in IDE)
TEA5767Radio.h (http://playground.arduino.cc/Main/TEA5767Radio)
EEPROM.h (included in IDE)
UTFT.h (http://www.rinkydinkelectronics.com/library.php?id...
Change the frequencies for the different stations, and the names of the stations.
When your sketch is uploaded, connect the battery by VIN, don't forget to check output voltage on the stepup module.
To charge the battery, you can use this : http://fr.aliexpress.com/item/Free-Shipping-5V-1A-...
I hope you will enjoy it !
And I'll make other instructables with the different parts of the projet (waiting for goods)
Regards
Aegnor
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    15 Comments
    Hi AxelP6! I have tried IDE, here is the error message I am getting.
    var/folders/1_/26sdktq539g8p1zdgwwmvkfh0000gn/T/build51d30eb09bbe7cc41ad360acb4b32d52.tmp/libraries/UTFT/DefaultFonts.c.o:(.progmem.data.SevenSegNumFont+0x0): multiple definition of `SevenSegNumFont'
    /var/folders/1_/26sdktq539g8p1zdgwwmvkfh0000gn/T/build51d30eb09bbe7cc41ad360acb4b32d52.tmp/sketch/DefaultFonts.c.o:(.progmem.data.SevenSegNumFont+0x0): first defined here
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
    /var/folders/1_/26sdktq539g8p1zdgwwmvkfh0000gn/T/build51d30eb09bbe7cc41ad360acb4b32d52.tmp/libraries/UTFT/DefaultFonts.c.o:(.progmem.data.BigFont+0x0): multiple definition of `BigFont'
    /var/folders/1_/26sdktq539g8p1zdgwwmvkfh0000gn/T/build51d30eb09bbe7cc41ad360acb4b32d52.tmp/sketch/DefaultFonts.c.o:(.progmem.data.BigFont+0x0): first defined here
    /var/folders/1_/26sdktq539g8p1zdgwwmvkfh0000gn/T/build51d30eb09bbe7cc41ad360acb4b32d52.tmp/libraries/UTFT/DefaultFonts.c.o:(.progmem.data.SmallFont+0x0): multiple definition of `SmallFont'
    /var/folders/1_/26sdktq539g8p1zdgwwmvkfh0000gn/T/build51d30eb09bbe7cc41ad360acb4b32d52.tmp/sketch/DefaultFonts.c.o:(.progmem.data.SmallFont+0x0): first defined here
    /var/folders/1_/26sdktq539g8p1zdgwwmvkfh0000gn/T/build51d30eb09bbe7cc41ad360acb4b32d52.tmp/sketch/F24LFWBIRTQJ5XR.ino.cpp.o: In function `loop':
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:65: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:72: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:75: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:80: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:83: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:88: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:91: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:96: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:99: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:104: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:107: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:112: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:115: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:120: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:123: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:128: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:131: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:136: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:139: undefined reference to `nadianne'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:144: undefined reference to `GroteskBold24x48'
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:147: undefined reference to `nadianne'
    /var/folders/1_/26sdktq539g8p1zdgwwmvkfh0000gn/T/build51d30eb09bbe7cc41ad360acb4b32d52.tmp/sketch/F24LFWBIRTQJ5XR.ino.cpp.o: In function `setup':
    /Users/jayfuller/Downloads/F24LFWBIRTQJ5XR/F24LFWBIRTQJ5XR.ino:41: undefined reference to `nadianne'
    collect2: error: ld returned 1 exit status
    Using library UTFT in folder: /Users/jayfuller/Documents/Arduino/libraries/UTFT (legacy)
    Using library Wire at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire
    Using library TEA5767Radio in folder: /Users/jayfuller/Documents/Arduino/libraries/TEA5767Radio (legacy)
    Using library EEPROM at version 2.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/EEPROM
    exit status 1
    Error compiling for board Arduino/Genuino Mega or Mega 2560.
    AxelP6, thank you. Do you have a better link, I got a 404 euro following that one.
    Hi Jay,
    Sorry i was fully at work these last days, send me your email address by PM, i'll send you the files for fonts.
    If you make a search in google on "rinkydinky font" you should find the site.
    Greetins,
    Axel
    I found the fonts! The link you gave me now works! It now loads to my Mega2560 just fine!!
    Oupsssss sorry "rinkydink" instead of "rinkydinky"
    Hi Jay, there's 2 possibilities, you can download the fonts here : http://www.rinkydinkelectronics.com/r_fonts.php
    Or you change the the fonts i included with the library 's fonts
    And verify if you libraries are up to date
    Regards
    Thanks a lot for your reaction AxelP6!!
    Hi AxelP6,
    Nice project, indeed simple. Only one question. What tot do with the button (connect to what)??
    Thanks.
    Hi Wim39,
    You just connect it to a digital pin with 10k resistor, and you change the stations which are loaded on the sketch, you can use the internal pullup, but i always prefer external one ?
    Greetings
    Sorry Axelp6, The button has 2 connection points. One of them to a random free digital input and the other to GND?
