It is not very neat, but I didn't have much time as it was only meant to be an alternative way of building an airsoft gun using a new system (part of my GCSE project). My design fired 9mm steel ball bearings, which is fun, but can cause injury.
This does use voltages upto 400V, and comnpressed air, so be carefull, and never put anyone at risk from whatever you manage to create.
The railgun is a form of linear accelerator, using a electromagnetic force to propell an object. The way that these work is that a electrical current is conducted up one rail, across the projectile, and then back down the other rail (see picture). This is called the Lorenz force.
Please ask if you have any questions.
This is my first instrucatble, so please be nice...
Remove these ads by
Signing UpStep 1Parts
For the Compressed air system; (step 4)
Gas reservoir- I used 4 small one, but a large single would be perfect, or use a spring.
2 gas valves- 2 gives a faster rate of flow, but not necessary if using a spring.
Pneumatics pipes- reservoir to valve to barrel connections
Steel tube (barrel)- diameter must be similar but slightly larger than you projectile.
For electrical (the rail gun)
I used 10 400 volt 450uf aluminium electrolyte capacitors (step 2)
Solid aluminium bar (for rails)- 20cm x 3cm x 3cm (step 3)
Acrylic 20cm x 3cm x 0.2cm
crazyjp got me thinking though... If you use the paintball gun as the initial means of propulsion and then build a rail gun around it, would it work? Like a "sleeve" that you bolt in place over the barrel with all the caps and wiring built in, all you will then need to do is find a way to activate the circuit automatically once the paintball gun has fired. You might have to cut down the barrel though, the standard barrel should be okay since they're mostly quite short and useless anyway.
The loading problem has also then been solved as most paintball guns are semi-automatic and have hoppers attached, all you need is a the correct diameter projectiles.
You might need some kind of separate battery-pack or else things will get real heavy. Unless you can find some small, light, long-lasting, high-voltage batteries.
i kinda need help asap!
i built a mixture of ur instructable and from how to make a railgun
i have 5 caps of rating 250v and 680uF each
that comes to about 3400uf
the rail type is from the other instructable
the main thing is that i am not able to fire anything
the voltages i used are from 7.5 to 12 v
i need help asap
oh yeah btw i used hack saw blades as rails ( removed the paint )
and no launch mechanism
thanks in advance!!!!
Akinich
I already trying to build one. But when i'm firing it, the ball bearing was not sped like your's.
In my design, i use two parallel aluminium strip and the gap between 2 rails is 2.1 cm and the diameter of the ball bearing is 2 cm. so,what i want to know is, does the ball bearing and the rail need to touch each other when it is fired ??
Thanks !!
I'm trying to build one of these for a school project. I plan on only using a small voltage (30V), like the one in your video, but I am having a hard time finding the right capacitors.
What if I have 45 100uF 35v capacitors @30V? Would that be enough to mimic what I saw in the video with only 30V and 10 450uF capacitors?
Thanks!
Right now, i am trying to build a railgun for my school project.
I want to know about the semi-conductor diode that you used for your project. What type it is ??
And for the rail, if i use two parallel copper strip (75 cm x 5 cm x 0.5 cm), will it work ??
Thank you before....
Blacks Cameras
I called every camera store in Vancouver, Blacks was the only one with a box of them.
They said that they like to keep them to go and smash, so they gave me 20 for free
1) How do you switch the power from the caps to the rails or are they always connected together?
2) Somewhere in the comments someone says:
"...But a 300 uf 100 volt capacitor stores the same potential energy as a 100 uf 300 volt capacitor...."
The actual formula for energy stored in a cap is 1/2 * C * V^2
300uf 100 v cap = 1/2 * .0003 F * 100 ^ 2 = 1.5 Joules
100 Uf 300 c cap = 1/2 * .0001 F * 300 ^ = 4.5 Joules
Thus, go for a higher voltage as the energy stored is related to the square of the voltage.
How does that compare to yours, power-wise and could I shoot 4.5mm bbs?
Im using 2 rails, each .5x 6x .25 sandwiched between plexiglass with bolts
Was only planning on aluminum foil, but Idk.
Havent built it yet.
its true they do but if you ask nicely they still might ;) i got 8 in 1 day the other day
A spring should be fine to use, the ball bearing just needs to be moving fast enough not to get welded to the rails.
The projectile I used was about 0.7 grams, but i'm not sure because the packet didn't say as most steel ballbearings aren't usually used as projectiles. Unfortunately I never got a chance to measure the velocity untill I needed the capacitors for my actually project, but in 3 or 4 weeks I should be able to give a speed for one firing a 6mm ball bearing with hopefully 400 volts.
