This tutorial will show how to create a part with a Stick profile on the edges of the part, as well as Cope profiles on the Ends. Profiles will be added to both edges and ends so as to allow the base part to be copied and used for all Rail & Stile parts. You only need to suppress the profiles not needed for the current part, thereby saving time by re-using the original part as much as possible.
You will want to read the Instructable on how to do an Extrude Cut Catalog Feature and be able to create your own Catalog Features before tackling this project. Also, you may want to be able to create your own raised panel to insert inside your new Rail and Stiles. The Raised Panel using Sketch Catalog Feature instructable will help with that as well
Remove these ads by
Signing UpStep 1CREATE A BOARD
Add Comment
