Rail/Coil Gun
Introduction: Rail/Coil Gun
I was told that I couldn't buy a BB gun, so instead I made my own version of a railgun that fires 320 Joules in a split second. I was able to pierce my garage door, but I had the switch blow up on me so I'm waiting to install the new high voltage switch.
Used components from old computers and random parts that I found in a voltage converter. So it took me about $30 to make.
But if you don't have everything then it will be more like $150 ($100 worth of capacitors)
Step 1: Material and Guide
Use the Schematic to build the Voltage converter.
You can find the same copy online:
I added a few things to the diagram to make an extra light to show how much the capacitor is charged.
This is the charger, you will need to make the switch using a high voltage transistor or a high voltage switch like the one in the picture.
Step 2: Build
Solder all of the connections in place using the schematics.
Changed out the high voltage transistor with high voltage switched (similar to a solenoid used for a door bell
Changed the resistors to make sure that your peaks and waves for the electrical pulses are at the right rate.
This will determine how much voltage you produce.
Make sure you set one side of the board for high voltage since you don't want any high voltage connections coming in contact with low voltage.
Step 3: Capacitor Bank
Ring up as many capacitors you want in parallel.
I glued 40 capacitors to a piece of wood and strung them up in parallel. Make sure that you use a thick piece of wire to hook them up so the electricity can travel faster. I also added a few resistors and a high voltage diode connecting the positive and negative end to make sure that the voltage wont backfire or arch. If it did then the capacitor bank will blow up. That is why I used 10 layers of duck tape and wood to hold the capacitor bank.
I made a 20 set capacitor bank, but it was not powerful enough.
Step 4: Firing
Just place the iron pellet at the start of the coil. Then let the capacitors charge and Fire!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    This appears to be just a coil gun not a railgun...
    This is cool!
    I bet you'd get more attention for your work if you had a really clear lead image. People tend to click on things they can see.
    Thanks for sharing this!
    Thank You!
    I never added the electronics to the gun model. I made this when I was 14 so I don't really remember what I did and I never had the tools to hollow out the wood so I stopped half way through the project.
    Oh, bummer! Anything stopping you from finishing it out now?
