Introduction: Railway Line Anvil
This Instructable describes how I made a small anvil for light forging work. It is made from a lump of railway line standing on end, welded to a plate of steel and firmly mounted to a hardwood stump.
Step 1: Technological Ingredients
Tools required:
Something to abrade steel with, I used a file and an angle grinder
A welder of some variety. I used a basic stick welder, though a MIG would have been easier to use.
Wood butchering equipment. I used a chainsaw and a hatchet but there are many other tools that could work
Drill - electric or otherwise
Heavy hammer
File card
Ring spanner
Chipping hammer
Personal Protective Equipment
Welding mask with correct filter glass - wear this when welding, obviously.
Protective clothing - Wear tough, close fitting, non flammable clothing when working with hot, heavy, sharp or fast moving things.
Protective footwear - This should be strong and non-flammable so they stop your feet being crushed and burned as badly.
Safety Glasses - May as well wear these the whole time, it's amazing how often stuff bounces off them.
Ear muffs - or other hearing protection. Wear when using loud tools.
Materials:
A lump of railway line or other heavy steel section. Finding this can be difficult if you don't want to spend too much cash but scrap metal dealers are a possibility. Looking around railway tracks may be dangerous and illegal depending on where you live.
A piece of heavy steel plate. This spreads the impact loads over a larger area of the wooden stand, increasing the effectiveness of the anvil somewhat. It also makes it easier to mount. I used a railway fish plate which is convenient because it already has mounting holes.
Heavy hammer
File card
Ring spanner
Chipping hammer
Materials:
Step 2: Prepare the Parts
Since I was using recycled steel I needed to remove the surface rust in order to achieve a reasonable weld. I used a chipping hammer and wire brush to remove the loose stuff, then the angle grinder to get back to bare metal. I marked an outline of the rail section onto the plate with a marker to show me what area to concentrate on.
On the end of the railway line to be welded I ground a heavy chamfer to aid weld penetration. When the parts were ground clean I test fitted them, removing more steel where necessary to get a close fit.
Step 3: Tack and Weld
With the parts fitted together, I attached the earth clamp of my welder to a cleaned patch of the rail and tack welded the parts together. I then used the chipping hammer to remove the weld slag and checked that everything was still well fitted. When I was happy with it I proceeded to stitch weld the parts together fully.
Welding stuff this heavy properly would probably require more power than can be supplied by a basic 240v AC single phase stick welder. In this application however, the strength of the weld is not particularly crucial. I didn't have any electrodes other than these quite small ones on hand, so I invented the trick you see here in the second picture. It worked well enough for me, but I'm not a welder.
Step 4: Stumping
To work properly, the anvil needs to be mounted on something heavy and resilient. Other criteria might include availability and theoretical portability as was the case for me. I used a section of a Flooded Gum (Eucalyptus grandis) log into which I cut a step. To do this I mostly used a chainsaw, and fine tuned the fit to the anvil with a hatchet.
WARNING: Chainsaws are really really dangerous and like to bite. Don't chop any limbs off or anything please.
Other combinations of concrete, steel and timber would also work well as an anvil stand. A good mounting will increase the effectiveness of the anvil and reduce noise.
I used some small pieces of steel plate and coach screws to attach the rail to the upright section of the stump. I also hammered steel spikes through the holes in the fish plate and bent them over.
Behind the new anvil on the top of the stump, I cut a notch and hammered in a small piece of light gauge rail. This provides more useful edges and surfaces on which to hit things.
I have not used this anvil extensively yet and I'm sure it will be modified later on. It does however seem to be pretty useful, and is good value for the effort required to make it.
Step 5: New Ideas
Well I've used this anvil a bit now and its limitations have caught up with me. The pictures below show a possible design, again using railway line. Ignore the shape of the horn, I'm still getting used to this CAD software. If you can't make sense of it, it's two sections of rail, on end, with the upper flanges together. This gives me a very well supported forging face of aout 70x80mm, just from the ends of the upper flanges. The brown parts would be welded on to give addtional area for straightening and bending. These would not stand up to heavy blows but would not really need to.
This design was derived from discussions on the Anvilfire discussion forum, with input from a number of members including the Anvilfire Guru. See the archived messages here, click on June 1 - 7, 2007 log.
Would halving the length of the upright sections reduce performance considerably? the second picture has tentative dimensions.
Any other comments?
ANOTHER EDIT
I added another drawing showing a second possibilty, involving a single upright section with a continuous face/horn piece welded on. Which is better?
AND ANOTHER EDIT
I decidd to go with the heavier option. No photos of construction unfortunately. The parts were cut using an oxygen/acetylene cutting torch and partially finished with an angle grinder. Welding was done with a MIG welder. My future holds quite a few more hours with an angle grinder.
Any other comments?
ANOTHER EDIT
AND ANOTHER EDIT
