Rain Barrel Lawn Sprinkler
 by nbonine
So, you live in a townhouse with a small front lawn. It never seems to get the water it needs to "keep up with the Jones who are retired and have a perfect lawn". And you have an erosion problem because your gutters collect water from all the roofs around you. Well, that is what drove me to this project.
I knew I needed to put in a "french drain" to deal with all the water coming down the spout, I also knew that I really needed an automatic sprinkler of some kind to keep the grass going through the hot periods here in Northern Virginia. Those thoughts spun in my brain until I saw this at my local home improvement store- for half price I might add!
Step 1: The Parts
This Deck Storage container was just the right size and shape to make a cistern for a small sprinkler system. I couldn't dig too deep for there were pipes in the same area- this is what kept me from doing a french drain in the first place (that and laziness). This container holds about 50 gallons of water and is made to stay outside year round. It has a lid that seals well. Perfect for making a buried rain barrel that could be the water source for a small sprinkler system.
pkemp2 says: May 19, 2013. 4:06 PM
Well done!
pcooper2 says: Aug 23, 2012. 12:16 PM
wilgubeast says: Aug 15, 2011. 11:49 AM
Nice project. Where are you sending the overflow from the cistern? Any possibility of turning your overflow into a french drain? That'd keep your roof water in your lawn, particularly if you are seeing a lot of overflow run out into the street.
Congratulations on solving your erosion problem. I think you'll be happiest with a drip system, if only because it is easy and low-maintenance. As an Instructables staff member, though, I say go for the Arduino/float array. :-D
nbonine (author) in reply to wilgubeastAug 15, 2011. 5:21 PM
I have the overflow going out on the sidewalk, but you are absolutely right. I do not like the exposed pipe end there either. If I can convince my wife to let me dig that corner of the yard up (again), I'll do it!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
