3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rain Barrel Project
Step 4Tools and Supplies
Obviously you need 1 or more barrels, my current setup is 2. All my supplies i bought at local hardware stores Menards, Home depot, Lowes, Fleet Farm, etc should have the same fittings all around the plumbing isle / home lawn sprinkler system isle.
Tools:
Spade drill bits (depends on the size of your fittings)
Drill
Utility Knife
Saw or PVC saw
Hammer (in case you get frustrated :-D)
Dremmel with wall cutting bit
Supplies - again these will vary with your setup, some of these will be needed for all setups some will depend:
For all setups you'll probably need:
Marie caulk - a small tube should work for this installation but if you want to expand in the near future just get a bigger tube
Pipe tape
Mosquito window screen (make sure it is rated to keep mosquitoes out!)
Some duct tape
Plastic spray paint (optional but sometimes necessary for white barrels to keep algae from growing or to make it look pretty!)
Variations:
1 - 5' (or 10') 2" PVC pipe
2 - 3 way or T 2" PVC fitting
2 - 2" couplings
3 - 2" male threaded adapters
1 - 2" female threaded fitting.
1 - 10' 3/4" white Pressure PVC (not CPVC which is tan in color)
4 - 3/4" T fittings
1 - 3/4" fitting with one side threated for valve
1 - brass 3/4" water faucet
2 - 3/4" caps for later expansion or added pump
4 - 1/2" sprinkler ribbed end (its gray and has 3/4" threaded end and a 1/2" end to slip a 5/8" hose over the end)
2 - 1/2" right angled sprinkler ripped end (its gray and has 3/4" threaded end and a 1/2" end to slip a 5/8" hose over the one end and can screw into the PVC in the other end.)
2 - double ended threaded PVC fitting (for the 1/2" right angled to fit into and then fit into the 3/4" PVC pipe)
2 - 3/4" right angled PVC fitting ( threaded on one end and smooth on the other)
4 - 3/4" metal tube clamps
1 - 3" PVC plastic shower drain.
1 - 10' of clear plastic 5/8" tubing
1 empty cat litter container
optional
PVC cleaner and glue (mine does not leak but i may do this when i do the final setup)
Filter
Additional / larger PVC
Different fittings (IE brass)
Pump
Pressure tank
"endless ideas?"
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:oddie1212
