Step 6Connecting the barrels together...
I put thread tape on the ends of the threads before I screwed them together. For in between the smooth ends i used the 10' 3/4 PVC pipe and cut it into smaller pieces that I pushed together.
Use the 5/8" tubing to connect the now screwed in fitting to the right angled 1/2" fitting. Also since this will endure the most pressure put hose clamps around the screwed in fitting and the right angled fitting.
Use the 5/8" tubing for the upper hoses also.
After thoughts:
As I stated before, I want to now use the PVC to screw into the sides of the barrels. This part was a little more daunting than i wanted it to be. As you can see the whole assembly sticks out a little farther than I'd like it to also. With using the screw in fittings it eliminates the need for the 5/8" tubing and extra fittings. I could put a T at each barrel along the longer pipe.
I would also put a shutoff valve at each barrel for easy cleaning or changing out a barrel with out emptying them both. Since right now it comes off the roof unfiltered.
Add Comment
![IMG_0089[1].JPG](http://img.instructables.com/files/deriv/FNM/P0TL/FJ0RH87J/FNMP0TLFJ0RH87J.SQUARE.jpg)
![IMG_0087[1].JPG](http://img.instructables.com/files/deriv/FEA/KTFY/FJ0RH886/FEAKTFYFJ0RH886.SQUARE.jpg)
