Step 9Place your system
I can't show that part since the current place I'm in doesn't have any gutters so it collects from a corner of the roof that 70% of the water flows down.
Make sure you have your barrels off the ground so its easier to fill things up if your going to use gravity. a pallet should work for this or concrete blocks. Make sure it is also as level as possible since the barrels will weigh a lot (~500lbs or 8lbs per gallon)
To comment about the drinkability and use of rain water, from what I've read and what i know the rain water is probably better for you to drink compared to city water. They say if your in a survival situation if you had a choice of drinking water out of a stream or drinking rain water you should always choose the rain water because there could be bacteria in the river water. It depends on the type of roof and barrels you use if you could actually use this to drink. You still need to filter it though with micron filters, charcoal, and probably UV light if you want to always use this to drink out of for whole house systems from what I've read.
Add Comment
