Material List:
- Food grade chemical barrel
- 3" X 1-1/2" PVC Coupling
- 3/4" Conduit locknut
- 3/4" Brass locknut
- 3/4" Drain valve
- 3" X 4" X 4" Downspout adapter (X2)
- 3" X 2" PVC Bushing
- 2" threaded PVC male adapter
- 3" 90 degree PVC street elbow
- 4" X 4" X 3" PVC sanitary tee
- All weather PVC cement
- PVC primer
- Marine Goop sealant
- Aluminum gutter screen
- TFE thread paste
Remove these ads by
Signing UpStep 1Install the Drain Spout
Installing the spout took a little ingenuity because I wanted to keep the integrity of the holes in the top of the barrel. So I had to fit everything through the 2" holes. I tied a small washer to a length of string and inserted it through the drilled hole at the bottom of the barrel. I taped a magnetic retriever to a broom handle and fished the washer out of the hole at the top of the barrel. I then fed the string through the 3/4" brass locknut and tied the end to another washer larger than the locknut. Place sealant on the barrel-side of the locknut and then feed the washer and locknut into the barrel. The second string tied to the washer in the picture is simply for control. I wanted to keep the setup from falling to the bottom or messing up the bead of sealant. With the locknut in position, keep tension on the string to keep it in place. Screw the 3/4" conduit locknut onto the drain spout and apply sealant to the barrel-side of the locknut and thread paste to the threads. Feed the loose end through the threaded side of the drain spout. You have to open the valve completely to do this. Align the threads and hand tighten. To get the spout completely tight I had to make my own tool that would fit through the 2" hole. The tool was made from a hold-on wrench ( either 1 1/4" or 1 1/2") bolted onto a 3' section of scrape copper pipe. Let the sealant harden for 24-48 hours before applying any tension or water pressure.
Fav'd
