loading
loading
Picture of Rain Barrels
After picking up 5 cheap 55 gallon barrels it was time to put my new gutters to use.
My goal was to create a modular barrel system that was first and foremost, CHEAP. I was inspired by a couple of other great rainwater reclamation systems here and felt I could put a different spin on the process.
This project came in at 220 gallons of water storage for less than 30 bucks a barrel. Everything was purchased via 'the bay' or 'home despot' except the barrels which I found on 'cragg's last'.
at the end I'll review some changes I'd make if I had it to do over again- but they're working great here in the wet N. Texas.
Step 1: Ingredients:
Picture of Ingredients:
Following this instructable will create TWO 110 gallon rain water reclamation units. This system is modular so it could be easily adapted to single barrel or multi barrel situations.
My list of materials:
4 55 gallon blue barrels (for the love of god make sure they're food grade, otherwise prepare to water your lovely garden with acetone, gasoline, or any of a dozen other lovely chemicals).
4 2 inch through-hull connectors- I'll discuss these lovely widgets later on.
2 threaded 2in PVC connectors (overflow)
18in of 2in ID (inside diameter) flexible hose (this stuff is big $$!)
2 standard threaded brass hose bibbs (connector thingies for garden hose- mine were 1/2in on the hose side and 3/4in on the 'connect to barrel' side).
2 4in drain hole covers
Silicone caulk
Drill
Dremel plastic/wood cutting bit for smoothing or widening holes in the barrel
Aquabarrel1 year ago
You'll find lots of parts to make your rain barrel project here:
http://www.rainbarrelparts.com/product_rbpEM_RSP_kits_rectangular.php
and here too:
http://www.aquabarrel.com/product_rain_barrel_plastic_parts.php
Pizzapie5003 years ago
DARN! You're soooo lucky! I've been checking Craigslist everyday for the past six months and the lowest the drums/barrels have gotten was $20 each.
A good name6 years ago
Where I live, you can buy them premade from the Goverment for like 50 bucks.
Would you tell me where or how these can be obtained? I live in the Rio Grande Valley in South Texas.  treelady
mplotsker6 years ago
For mosquito control I heard that putting a few cheap goldfish into the barrel will solve that problem. The fish will eat the eggs and larva of the bugs. I don't know how well this will work. I just heard it works.
i always thought mosquitoes bread in small, still, shallow pools of water so if you have an ample amount of water, mosquitoes shouldn't be a problem.
But i have heard that about the goldfish as a general water pest "killer"
I have heard that too. You can also put 1-2 drops of oil on top, which keeps the mosquitoes from breeding.
PepeAs5 years ago
Mosquitoes Out!
I don't know if anyone mentioned this already. Build a sand filter with a vertical section of gutter pipe that it easy to disassemble for cleaning. The vertical placement facilitates the draining of water from the sand to avoid that the moisture attract to the mosquito. I think that an ideal filter would be of varying thickness of sand (three, for example).
Place the filter in the bottom of the downspout of the gutter, at the entrance to the reservoirs. This will prevent both the entry of solids such as mosquitoes to deposit.
What do you tink about this idea...?
Greetings from Spain
cricut6 years ago
This is a great idea but wnat do you do about mosquitoes.
CamWaite cricut6 years ago
sawyz6 years ago
Thanks! We are getting ready to put our garden in and this is exactly what I was thinking of doing...now I have a good idea of what I need to do. Again Thank you for the excellent Instructable. BTW this is the first time I have ever posted a comment.
RyanDW7 years ago
Have you considered putting a drain bibb at the bottom of the 1st tank so that you can drain the inevitable "roof sludge" that you will slowly build up on the bottom of the tank? Also either lowering the bibb on the 2nd tank, or perhaps using a 2nd bibb on that tank for the same reason may be good. In order to keep bugs out of the tanks, you may want to run the pipe from the gutter straight into the tank and then use a separate, external, "filter box". I've thought about doing this very same thing .. great idea!
Had a couple thoughts on this. 1. design the system such that barrel one is a French well. outlet being placed somewhere 2/3 up the sidewall. This should allow the water to settle out the particulate and not advance to the actual reservoirs. 2. if that first barrel were designed like a trombone, then you could adjust the water level for discharge based upon season rain event expectations. such that a lighter rain will get into the reservoirs. 3. as the barrel is likely to be near the foundation. design the french drain floor to be within a larger barrel. then plumb an outlet to tile system away from your buildings to drain the french drain and reduce mosquitos concerns. 4. as the first barrel is now slidable. Make it so that it can be removed. Now have access to clean out the floor of the french drain annually. 5. don't fixate on passive drainage of barrels only. They do make solar powered water pumps. Using these you can pump the water from the barrels to where ever you need it. Such as a soaker hose irrigation system, etc. 6. By pumping it, you can then submerge the tanks into the ground. Just be certain to call your states "Call before digging" hot line so as not to break a utility line. Save some dollars and possibly a life.
smilestill7 years ago
Where do you find these barrels?
I stopped a scrap dealer in his pick-up and trailer and he delivered two white Plastic 30 gallon, and two 55 gallon blue plastic barrels for $20 total, with a promise to bring four more blue 55 gallon plastic barrels for $20. Plastic gutters for my two 50 foot rooflines ran a total of about $150 for everything, I also arranged for putting aluminum flashing (50 foot roll, $18, at Lowes) on the edge of my neighbor's roof (under shingles, above existing edge flashing), to drain over into my gutter between our homes where the foundations are only 4 feet apart, and the roof edges are 10 Inches apart! These 1555 sq. foot homes have peaked roofs that flow thousands of gallons in a normal year in Florida! Overflow, if any, will go down hoses from the barrels, and into the nature preserve behind the property. This will remove a serious foundation wetness issue for both of our homes. For the proper 'HEAD' pressure to feed soaker hoses, every 27 inches of elevation of the faucet gives 1 psi. So, I will build a barrel rack of Landscape timbers, about 3 feet of the ground, and place the faucet another two feet up on the feed barrels.
For a really aesthetically pleasing barrel, I recommend trying to find a distillary or vinyard nearby. I live in KY, and since bourbon barrels can only be used once (by law), my rainbarrels are all constructed using these - purchased for $10 ea. after being used by a microbrewery, so twice recycled!
I found my barrel at a feed and seed place for 12 bucks. i had to add the spigot myself. also you could check a winery.
pyroswmr6 years ago
i built one of these a while back, and found that the main issue was the whole gravity fed limitation... so ingenuity prevailed! when i first built the system, i kept the original bung intact as the only inlet, and tapped a tight fitting outlet near the bottom. the easiest way other than using a pump was to pressurize the barrel with air. i put a simple 1/4" air compressor valve in the top, and now whenever i need pressurized water, i just run a line from my 80 gal air compressor and turn the water valve open. it works kind of like a giant super soaker! be careful not to over pressurize it though, I'd recommend getting a regulator and setting it for only 20-30 psi.
great! Oh you could water plants-grass w that, or mabe.. just mabe, hook something up to use that in a toilet :-P? huh? huh!?
I wouldnt want the bad water (sometimes) coming thru rain going in my ERM.... a**
Bardouv7 years ago
Great work. I did something similar a couple of weeks ago. Carolina is in a big drought so we bought 8 barrels, and we set them up on cinder blocks and connected them underneath. We also have a seperate barrel to collect runoff from our showers and washing machine. Our only trouble is finding a pump strong enough to handle the long, uphill distance to our garden.
Tocsin (author)  Bardouv7 years ago
That seems to be the biggest drawback to any of these systems... you're really constrained to gravity for the flow. I've taught my kids to fill buckets and use the water for my potted plants and the garden, it's been a great option to have and now that the vines are growing up around them they look like part of the yard.
fillerup7 years ago
Nice instructions! Where do you buy the "thru hole" thing to put the spigot on the barrel? Is the tapped spigot on your 55 gallon barrel a 1/2 incher? How much did the "thru hole" thing cost?
This barrel rainharvester / collector is tapped with a 1/2" threaded barbed connector. They cost 60 cents?
http://www.rainharvester2.blogspot.com
Thats alot of rainwater!!!
Tocsin (author)  fillerup7 years ago
I found these fittings on ebay. They run about 2.50 to 5.00 each. I don't mind the threaded approach of the link above, however, I wasn't sure how thick the barrel walls were and I wanted to move more water than the traditional lawn fittings would allow. These 'thru hull' fittings are extremely strong because they sandwich the barrel sidewall between two thick plates, keeping the pipe from twisting out and allowing a wider diameter hose. I was worried that a small diameter hose wouldn't allow water to pass between barrels quickly enough. The tapped spigot is indeed 1/2". Thanks for the feedback!
Krystine7 years ago
Good to see folks using rainwater to water their plants... my husband linked four rainbarrels together and put them up on a platform. Works like a charm ;)
Step by step instructions here: http://tinyurl.com/3x55xg
I elevate my barrels on wooden stands (concrete blocks might also work, depending on your aesthetic), to give more head (sorry, it's also a correct technical term), for garden hose use, or to fit a watering can under the draincock (no, I did not post for the sole purpose of immature double entendre humour). Here's a cautionary tale regarding overflow hoses. If you live in an area that experiences winter, make absolutely sure to plug or screen your overflow fittings! I put one of my rain barrels away on its side one fall. (Freezing a full barrel is a very good way to break the bottom out of it.) Unbeknownst to us, several mice decided to venture up the overflow hose and explore the barrel. Unable to get out again, they expired there. Next spring, when the draincock plugged, I poked inside the tap with a small stick, and was met with a trickle of evil smelling water. On opening my barrel (it was one of those big brown olive barrels with the screw-top lid) I was confronted with the horrors within. Trust me on this. Few things rival the stench of decomposing mouse.
Tocsin (author)  incorrigible packrat7 years ago
Great points. I also put some bricks under one of my barrels to elevate it. (the other pair sit on a slope so no need). I am right now going to get some anti mouse screen. *shudders*
I have heard that Irish Spring soap is reputed to repel mice, deer and other common garden pests. I bought some to try this out (though not in my rain barrels, as I don't really need pungent green lather on my veggies next spring). I can attest to the fact that it repels me. I don't know what would possess anyone to actually wash themselves with it. Lordy, but it smells bad (well, not quite as bad as the dead mice).
chuckr447 years ago
2 summers ago I made my own rain barrel. My garage is detached but had gutters, so the output from the garage gutter goes to the barrel. I made a square frame out of wood, then put window screen on it. I put this on top of the open barrel top, and it lets water in but keeps leaves, debris, and mosquitos out. I have no mosquito problems with this barrel since the screen is mosquito proof. Also, after the leaves dry out, a wind blows (most of) them off the screen. It is self cleaning! Unlike a funnel-shaped top.
tanda3337 years ago
I had something similar at my cottage (we have no running water there, but oddly enough, we do have satellite iv) but what we did is got barrels with a sorta lip at the top, then cut out the entire top of the barrel so that it is completely open at one end. and then we put an old bedsheet folded over itself several times(with a steel mesh on top) held on with bungie cords wrapped around it just under the lip. this filtered the water (at least from animals, bugs, and debris, and served as an overflow.
canida7 years ago
Nice job! We've been thinking about doing this too; thanks for the great suggestions.
Tocsin (author)  canida7 years ago
The biggest stumbling block I had was how to connect them easily- the through hull makes this REALLY simple. Good luck with your project- it's well worth doing. Search "the bay" for 'thru-hull' or 'through hull fitting'. 2in seems to be the biggest diameter without getting spendy.
Tocsin (author) 7 years ago
Nothing like scatalogical humor to keep people reading til the end.
imagine the water comes out like poop EWWWWWWW hahahhaa all acting like a little kid
