3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rain Barrels
Step 3Tying Two Together
Tying Two Together
since I really couldn't stack these vertically given my wife's aesthetic needs (I'm not having a great ugly mashup of plastic towering around my house!) I chose a more subdued configuration. This necessitated holing the barrels and connecting them.
After hunting for bits and pieces I came across the perfect fitting- a through-hull. These are used on boats to pass fluid (grey water and cooling for engines I presume) through the hull without sinking the boat.
I drilled a 2 inch hole and put one of these fittings about 6-8 inches from the bottom of each barrel. Since these fittings are typically barbed, it made for a great fit with the plastic tubing. Just make sure the through-hull fitting and the tubing are the same diameter.
The easiest thing I found was to fish the through-hull through the reamed bung hole (yes- I reamed 4 bung holes to complete this project) using a coat hanger. I placed a nice bead of marine grade silicone on the flange and tightened the nut from the outside of the barrel. This cinched down nicely and made a watertight fitting.
I tried this with an 18in length of tubing and found that 1/2 that length is better.
1 comment
Mar 12, 2011. 2:56 PMgarden goddess says:
Yes, we find that linking multiple barrels as low as possible to be the best design for several reasons.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:Tocsin
