Rain Gutter Cleaner
 by knorseth
Contest WinnerFeatured
Step 3: Using the cleaner
To use the cleaner, first change into clothes that can get wet.  You will until you figure out how to use it.
Close the valve on the cleaner
Connect your garden hose to the base of the cleaner.
Turn on the water.
Put the hook of the cleaner into the rain gutter.
Turn on the valve.
Go back and forth along the rain getter until the gutter is clean. The rain gutter has clips every couple of feet, you just need to lift up the cleaner to go over them.
If the rain gutter is full of debris, then you will want to start at the end with the drain and flush it out.
If you have a pergola connected to your house, you can turn on and off the water at the valve as you go around the trusses.
If your drain is clogged, this will work great to flush it out alone.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
