Rain Water Harvesting: Water Self Sufficient Home
This will not be so much a how to build, as a how does it work and look guide.
I will show you how a water catchment system can work to run your entire home without any water from the outside world. This system does need an electric pump to maintain water pressure, so you do need to have electricity, eventually this could be on a solar system.
Technically you could probably drink this water, however we do not. It runs 100% of the plumbing in our house, the house has ZERO water from the outside world. The only source of running water in the house and on the property is supplied from this catchment.
TO make the water 100% potable, the system should have:
first flush filter
Tank feeder line not underground,
UV filter
Also the house has a steel roof.
Step 1Rain gutter downs spouts
All rain gutter downspouts are routed through pvc pipe and all join together to feed the tank.
33 comments
Jun 10, 2011. 7:51 AMdewexdewex says:
Could you tell me how large the individual corrugated panels for these tanks are, please? I may get a tank similar to this and I have to make sure the parts will pass through the property, as there's no access to the rear garden other than through the property. Thx.
Jun 10, 2011. 7:17 AMdewexdewex says:
Does anyone supply these tanks with a gutter around them so they can be used as a collection area?
May 13, 2010. 5:36 PMRelientOwl says:
Question: How does the water from the roof get to the tank do the water levels just equal out and kinda spill into the tank?
Feb 7, 2011. 9:17 PMbeecroft says:
Great, I was wondering that as well. So the pipe just goes down and then back up, right? Did you provide any kind of clean-outs there? And how do you prevent leaves, etc. from getting in?
May 14, 2010. 11:17 AMRelientOwl says:
Cool!!
Feb 28, 2011. 5:46 PMrudi138 says:
808blogger
I was wondering where you bought the panels for your tank.
they look a lot like grain bin panels. Is that what they are?
Oct 30, 2010. 12:42 PMuberdum05 says:
Wouldnt particularly use plastic pipe (PVC) for high pressure water, maybe for the feed for the pump. for the high pressure side I would use either copper or plastic barrier pipe (JG Speedfit) :)
Jul 31, 2009. 5:34 PMbwpatton1 says:
Wow, where do you live that provides this much rain? LOL, this would be a cool system to build, im still trying to convince my parents to put in gutters so we could do rain barrels LOL
Aug 1, 2009. 8:55 PMbwpatton1 says:
Ahhh, unfortunatley down here in Houston, the rain isnt often enough to provide sufficient water supply.
May 18, 2010. 9:07 AMlalalaux says:
You sure? I don't know what Houston gets for rain, but a water harveting guy in Arizona swears Tuscon, with it's 12 or so inches a year, could more than supply it's own water if they caught it. Unfortunately, we prefer to drain or rivers and aquifers instead.
May 20, 2010. 6:24 PMlalalaux says:
I'm not sure, but I think he's counting commercial buildings, etc. Still, in the desert every little bit helps. Here's his website. http://www.harvestingrainwater.com/
Aug 1, 2009. 9:01 PMbwpatton1 says:
Kudos though, this is a very interesting project, only wished I could build this :(
Jan 4, 2010. 10:44 PMtheseep says:
Great work!  I'm looking to build a similar setup - how are you controlling the pump to fill the pressure tank?  I'm going to use this for garden/fruit tree irrigation so I need it to work with my sprinkler controller, any suggestions?
Apr 25, 2010. 9:07 PMzieak says:
I had a system like this on my home 5 years ago.  I didn't have mine covered and had it freeze over a few times (I live in Alaska).  But i drank the water for 3 years.  I had the gutters run to a pope which poured straight into the tank behind the house.
Dec 17, 2009. 3:58 PMrcallan says:
I am thinking of trying this on a smaller scale to run the washing machine and feed the hot water tank.  I need to keep the tank and pipes from freezing so it would have to be in my basement or burried below the frost line.  It may not collect water in the winter.  Thanks for the pictures this is very helpful.
Oct 29, 2009. 3:23 PMwesthebeekeeper says:
were you on tv ever? i saw a guy in hawaii with one of these catchments
Oct 5, 2009. 11:49 AMsiliconsurfer says:
Great system. What size is your collection tank & have you changed your usage patterns to accommodate not having water 'on demand' Do you 'recycle' any of your grey water & what do you do for your drinking water?
Oct 1, 2009. 11:04 AMllanyort says:
what are the shingles of your house made of ? and how does that configure with possible contamination and filtration ? i don't think I would use this for a shower/bath/sink/dish washing but definitely toilet flushing and gray water usage. but this does sound like a great idea !!!
Jul 31, 2009. 10:46 AMjwaterfallguy says:
Very cool, what part of the country are you in? What's cool about your system is that your reservoir is big enough to sustain your house, nice! Could you re-post this on our rainwater harvesting forum? Our community would love to hear about this!
Jul 14, 2009. 6:42 PMOroka says:
If you were building a new house, you could incorporate something like this from the start. Plumb the house to use town or well water for drinking, and then use collected rain water for toilets, laundry, watering the lawn in a separate system. You could even build a under ground tank for the water, just have all gutters piped in there. A system like that reminds me of a 'grey water' system on a ship. You can wash, do laundry... etc with it, but don't drink it. I will be building a new house in the next 5 years and am finding ways to stay off the grid, or be as independent from the grid as possible (solar, wind, battery, rain water... etc)
Jul 13, 2009. 7:40 PMr-philp says:
Very impressive. I've often considered doing this , but how do you clean out the bacterial gunk that would be introduced by bird poop, and whatnot on the roof? Doesn't that tank eventually become a big petri dish?
Jul 13, 2009. 11:54 PMTransquesta says:
Well, I suppose both tank and contents can be treated chemically from time to time--plush which he does have an inline filter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:808blogger
