3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rain or Shine Solar Charger
Step 9Hardware part deux: components
The charge controller is the heart of the system, and unfortunately is the only part that isn't an off-the-shelf product, so we're going to have to make one. Its not something that can be made from standard Radio Shack parts, because it runs at very low voltage and needs good precision. If you’re not feeling up to the task of making one after reading this section of the instructions, don’t despair. I made a few extra and have them in my etsy shop blondietheblond.etsy.com. You could also order all the components in thru-hole variants and build the circuit on perf-board if you prefer. Just make sure to use 1% resistors.
The first step is to collect all the components. The following will be required:
PCB components (Parts express www.partsexpress.com is a good source.)
Pre-sensitized single sided copper clad board, at least 1"? square
Developer for above
Ferric chloride
Small drill bit (1/32 or so)
Transparency film
Printer
Electronics: (www.digikey.com would be the standard place here.)
1 Op Amp MCP6002-I/SN-ND
1 Dual AAA battery holder with leads BC2AAAW-ND or Radio Shack
1 shottky diode MBR0540T1GOSCT-ND
1 zener diode 568-3779-1-ND
2 100k ohm 1% 0603 resistors
1 5k ohm 1% 0603 resistor
1 16.2k ohm 0603 resistor
1 3.9 ohm 1206 resistor
1 MOSFET FDS6898ACT-ND The MOSFET has to be fully turned on by 2v for this to work, so make sure if you're going to substitute
1 AnyVolt Micro universal DC-DC converter (http://www.dimensionengineering.com/AnyVoltMicro.htm, not available from digikey)
3 Powerfilm MP3-37
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=359081
1 Charging plug for your cell phone or other device.
2 AAA NiMH batteries
t if you have to contact the president regarding the aliens' one weakness, it might just save the planet.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:blondietheblond
