Rainbow Chandelier
7,145
64
7
Posted in CraftArt
Introduction: Rainbow Chandelier
    This 'ible will show you how to make a pretty and colorful chandelier out of test tubes and food coloring. The project was originally intended to use chemistry indicator solution to act as an artsy demonstration of pH dyes. However, due to a faulty indicator dye that I ordered, we decided to use food coloring instead (it is also prettier). The project was used with the faulty indicator dye (and later switched to food coloring) as a demo for my homeschool teaching position. For older students, indicator dye is a good experiment for  observing pH in everyday objects and learning to use pH sensitive materials (the dye and litmus paper as well). For younger students, the coloring could use the food colorants to have some fun mixing colors while trying to make a color wheel.
    Through building this color wheel, young students will learn the elements of mixing colors to achieve new colors. The mixing of primary colors is a basic part of all of our educations. At the same time, older students could adapt the color element to learn something about the elements. The chemistry behind  Acid / Base mixtures with respect to their concentrations is easily taught with the use of color-changing indicator dyes. Either way, its really fun!
    The inspiration for the entire project came from tumbling across the last image on this step. (source fails to be cited!)
Step 1: Materials
Materials:
Wood for the wheels supporting the test tubes
String or wire to hold them up
Food coloring (water-based works best, but any kind will do)
Test tubes
     I ordered my test tubes via Carolina Biological Company
http://www.carolina.com/category/equipment+and+supplies/glass+and+plasticware/tubes.do
     They sell boxes of 48 test tubes for around $10 to $15 and have decently priced shipping. A good company!
     They also sell universal indicator solution (not great quality, but still decent) if you want to use the chemistry approach.
Equipment:
A 1/2" drill was used to drill the holes for the tubes
a bandsaw was used to cut the circles for the wood form (use whatever you want here though)
and a tiny drill bit was used to drill holes for the string
Step 2: Wooden Frame
Decide approximately how big you want your chandelier (I went with 9" diameter for the larger circle). Outline the circle. To do this I used a funnel since it has a circular rim to trace. Using the bottom of a paint can or a dinner plate would also work.
Use the bandsaw (or whatever you have, handsaw, etc) to cut out your circle.
Now the tricky part!
Make sure to leave room for the 1/2" holes you are to drill later, but you need to cut out an inner circle.
You need (want) to cut out the inside of the circle to make it a donut shape. I cut though the rim and just went crazy with the bandsaw until i had the center cut out. You can then glue the rim back together with wood glue (or elmers even would work fine).
Make a similar scaled down clone using the same method. This is the second ring and is a few inches smaller. Mine is about 6.5" in diameter.
If you want simplicity, you do not have to make this second ring, it will still be cool!!!
Step 3: Drilling Holes
First, decide how many test tubes you will be using. I used two rings of test tubes. The first ring had 16 tubes, the second had 8 tubes.
I made approximate marks for where to drill each hole for the test tubes. And then drilled them with 1/2 inch drill bit.
Now would be the time to paint the wood if you want to. I spray painted them black with a hint of red.
As a substep, drill holes in the circle's edge. I drilled 3 holes (approx. at 1/3 intervals) for the wires to hold them up. Then thread the wire through these holes. It should be hang-able now!
Step 4: Color the Tubes!
This is the fun part! Fill each test tube about 2/3 ~ 3/4 full with water. Now pick whatever colorants you want and try to make as many pretty combinations as you have test tubes for!!! The simple pretty ones are making pure red, pure green, pure blue, and pure yellow. Next you could try one drop of each colorant. From here you can try whatever you want!
Precaution: your sink may become messy (as will hands, clothes, anything nearby). It IS washable but fair warning!
Hint / Note: purple is hard to make!
This step shows a bunch of pictures of the colors i made.
Please post pictures! Especially if you make a nice purple!
    • Spotless Contest
      Spotless Contest
    • Slow Cooker Challenge
    • Flowers Challenge
      Flowers Challenge
    7 Comments
    This.is.freaking.awesome! I was just looking at websites for inspiration for a new light fixture in my dining room that was colorful and fun, and not stuffy at all. This is nerd-tastic, colorful, AND a fun project for my son and I to make! Thanks for publishing this! :-)
    thanks! that is exactly what I like hearing from ibles
    That looks awesome. It'd be great to see a pH version for older students. As a matter of fact, I'll put a bounty out on it. 1 year of pro membership to someone who can show us a version that uses indicator dye to illustrate pH.
    a link it to the comments here please! I was only able to get 1 blue, a ton of reds and yellows and one green (not exactly a color wheel) using the indicator dyes.
    this would make any room at least 20% cooler
    Wow, this is gorgeous!
    Reaaly cool! Thanks for share :)
