3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rainbow LED Paperweight
Build a mesmerizing and entertaining paperweight with lights that slowly change color.  This project embeds a simple circuit consisting of nine color changing LEDs in a paperweight made of epoxy resin.  Constructing the circuit requires very basic soldering skills and the epoxy resin for making the paperweight is very easy to work with.  The result is a terrific paperweight for anyone who likes desk toys or gadgets with blinking lights and the paperweight makes a terrific gift.
This video shows the Rainbow LED Paperweight in action.
Step 1Parts List
Parts List
You will need the following parts and materials for this instructable:
Paperweight Materials
  • EasyCast Clear Casting Epoxy Resin (8 oz kit)
  • Castin'Craft MC5 Mold (3" diameter x 1 3/8")
  • Black pigment for polyester, epoxy, and urethane casting
  • Castin'Craft Mold Release
  • Multi-color glitter
  • 6 Plastic mixing cups (you will use two when mixing each layer)
  • 6 wood mixing sticks or tongue depressors
  • Plastic gloves
The EasyCast Epoxy Resin, Black Pigment, Mold Release, MC5 mold, and mixing supplies are available from TAP Plastics.  Glitter can be found at most art or craft stores.
Electronics
  • Nine (9) slow color changing RGB LEDs
  • 9 volt battery
  • 9 volt battery clip
  • 270 Ohm 1/2 watt resistor
  • Solderless breadboard and wire (optional)
The LEDs are available on eBay (I got mine from the eBay seller "bestshop2008hk").  The rest of the parts are available from RadioShack or most electronics parts suppliers.
Miscellaneous
  • Small piece of scrap corrugated cardboard (4" x 4")
  • 3" Diameter round cardboard container lid or something similar (available at craft stores like Michaels)
  • Black Sharpie for coloring the cardboard container lid
  • Small rubber feet with adhesive backs (available from any hardware store)
Tools
  • Awl or equivalent pointy tool
  • Wire cutters / wire strippers
  • Soldering iron and solder
  • Scissors
4 comments
Jun 17, 2011. 7:17 AMagis68 says:
wow! really beautiful
Oct 25, 2010. 8:28 PMgloriousfactory says:
we are manufacturer of leds in Guangzhou, skype: gloriousfactory
Sep 18, 2010. 10:48 PMElectronics Blurred says:
Erm , excuse me sir , how do you add 3 LED's and a resistor (which is even larger then my circuit) .
into a 9V circuit ?
If it's parallel , i would believe you .
2 in a line at max . and a 150ohm resistor .
this how i wire it up .
I Positive
R Resistor 1
O LED 1
O LED 2
I Negative
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:talk2bruce
