Introduction: Rainbow LOVE Marquee
Picture of Rainbow LOVE Marquee
I'm getting married at the end of the month and I wanted to do something electrical and magical for my gal for a centerpiece of the table. Since we are getting married just blocks from Philadelphia's "Love Park" i decided to take the iconic statue and transform it into marquee letters with pixel leds controlled by an Arduino. Adafruit's Neopixel library enabled me to add a rainbow lighting pattern that looks really groovy.
Step 1: Parts & Tools
Picture of Parts & Tools
Parts:
1. 3/4" MDF, approximately 2' x 3'
2. Poster board - 1 sheet
3. Hot glue
4. Pixels string - at least 35, I used these: WS2811 Pixels
5. Arduino - I used a Nano
6. Momentary switch
7. On/Off Switch
8. Brackets - angle and flat
9. Spray paint - Silver metallic or whatever color you wish
Tools:
1. Scroll or Sabre saw
2. Circular saw
3. Drill and bits
4. Glue gun
5. Sander or sand paper
6. Screwdriver
Step 2: Layout
Picture of Layout
The following drawings were used to layout the letters. I saved it as a PDF file. The drawings are set up so that they can be printed on (2) 8-1/2" x 11' paper for each letter so you will have to line up the two pages to make one layout. Use the lines as match points and overlap the two drawings on a light box. If you don't have a light box hold it up to a window.
Tape the layout letters and tape them directly to the MDF. Try to line up straight edges where applicable as shown in the cutsheet. Drill a hole in the center of the "O" so you can cut out the inner part. Once laid out, cut the MDF into manageable 1-letter pieces. Use your scroll saw to cut out the letters. Cut out the base also.
Sand smooth when done. Drill 1/2" diameter holes for the pixels, as shown in the drawings, making sure that they are no farther apart than 3". (If using a similar pixel string I used. check before drilling all the holes, you may have to adjust as needed according to your pixel string).
Step 3: Add the Edging
Picture of Add the Edging
I used poster board to make the edges that will keep the lighting inside the letters. I made them 1-1/2" wide by 36" long. You will need (2) strips for each letter. One sheet should be enough to make enough all the letters.
I used a glue gun to adhere the edge to the letters. Carefully map out how to apply the edges. I started on a corner and worked it around one side at a time. Crease corners and be careful, hot glue is hot! Work all the way around until you are finished. DO NOT USE ELMERS GLUE! It will ruin the paper and make it extremely wrinkly and the set-up time is way too long.
Step 4: Assembly
Picture of Assembly
To assemble you will need to use different brackets as shown. I started by centering the "V" and "E" on my base and placing my angle brackets where needed, 2 per letter. I then predrilled small starter holes and then used a power driver to drive the screws tight. Once the two base letters were done, I added the "L" by lining it up with the V below. Here I used two rectangular plates using the same predrill and screw method. make sure the brackets and plates don't cover up your pixel holes! The "O" is slanted at about a 45 degree angle away from the "L." Notice the orientation because I initially leaned it the wrong way and had to redo it. I used the longer plate flat bracket and the plate to attach the "O."
Step 5: Painting
Picture of Painting
I used a metallic silver spray paint to make my letters look like a galvanized sign. You can use any color but be aware that the pixels will make the color. Paint carefully in light coats until all is covered. Don't lay it on too thick as this could cause the poster board to wrinkle. Since I was going for a "vintage" old look, mistakes in painting and defects just makes it look more antique. I decided that I wanted to paint the outside white as an overcoat.
Step 6: Install the Pixels
Picture of Install the Pixels
The pixels should fit snuggly into the 1/2" holes so you shouldn't need any glue. Be aware of the direction of the wires as indicated on the pixels. There is a small arrow indicated "Input" and "Output." Wire your nano to pin 3 for the data and the power to 5V and ground to GND. The button was placed on pin 6 but you can place it on any pin you please. One side of the switch goes to the pin the other to ground. I used a rocker style switch to turn my display on and off. This depends upon how you want to power your display. You could use a usb transformer with a micro end for the nano. Then to turn it off, just unplug. If using battery power, just put the switch in.
To install your pixels, start at the top of "L" and weave your way down thru the letters as shown. Follow the pattern and it should fit pretty well.
Step 7: Solder the Circuit
Picture of Solder the Circuit
I originally ran the marquee off a 9 volt battery but changed it to a cell phone charger with a micro usb I could plug right into the Arduino Nano. For the wedding I ran without the momentary switch so that it could cycle thru the patterns without my input since I was busy getting married and stuff.
Step 8: Code
Load the adafruit library found here: Adafruit NeoPixel Library
If you have problems, Adafruit has many tutorials on how to load libraries.
Once done, upload the code and watch the magic!
The sample code given is the one I used at my wedding. It just cycles thru all the different patterns without using a button.
The second code is with a button you press to change patterns.
mrdepths (author)2015-08-25
great idea and i wanna make it, however i'm struggling with the arduino software. how do you install the sample code to the arduino? i'm a bit confused
boscopsoultrane (author)mrdepths2015-08-25
Have you ever used an arduino before?
mrdepths (author)boscopsoultrane2015-08-26
Hi. New to it, ive created a sketch and uploaded to the nano but when i try to compile yours it mentions that one if the files hasnt been announced.
boscopsoultrane (author)mrdepths2015-08-26
I dont know what you mean.
Did you load the library?
Do you have all tabs available?
dangerous dan (author)2015-07-08
I've got one of those "LOVE" pieces that my step daughter bought my wife!
It's made out of tin, and the led's are just cheap screw-in retrofit flashlight bulb type. It hasn't really worked since we got it, so we never turn it on.
BUT NOW, I have a use for all of those discrete WS2812B Neopixels I got by ACCIDENT!!! I may use a Digispark kickstarter micro usb, and an 18650 battery.
thanks for the inspiration!
that would be really cool, that would make it wifi enabled? you could put it on a wall and not worry about cords and change patterns remotely. i have thought that using a nano was over kill since i am only using 2 I/O pins. i was thinking of adding a dance mode with a color organ that it could respond to the beat of the music. now you have inspired me...
do you know what happened to the other pictures and files
dangerous dan (author)killer51502015-08-04
I don't know! there used to be some great video of the love sign in operation!
killer5150 (author)dangerous dan2015-08-04
Ya and some great pictures of the wiring
i don't know what happened either. I added back the videos. I will have to recreate the rest. Sorry.
Are you going to be able to make the wiring diagram and it seems like it would be esier to put it in the comments.
ok
Thank you soooooo much.
Thank you so much all I was really looking for was the wiring diagram
The Digispark kickstarter micro usb doesn't have WIFI, but there is plenty of memory for projects like this. I would think that a color organ would fit nicely in it! Also: Here are some pictures of those WS2812B Neopixels I got by accident! (the description stated that they were opto-isolated 5V relays!)
Oh, I looked up the wrong thing... I looked at the Oak by Digistump which is WIFI enabled, Arduino compatible. It was right below the micro USB.
killer5150 (author)2015-08-04
what happened to the all attachments and other pictures
killer5150 (author)2015-07-08
what did you use for the power supply?
I just updated the 'ible with a schematic. You can use a 9 volt battery, a micro USB cable from the Nano to an USB with a transformer, or you can use a power supply of your choice from 9vdc to 5volts.
Thank you
Wendy Goldberg (author)2015-07-08
Love it Bosco! You rock!
I assure you that I am not a rock.
pristinabread (author)2015-07-08
THIS IS THE BOMB!
I assure you that it is not a bomb.
About This Instructable
1,996views
58favorites
License:
More by boscopsoultrane:Rocking Granny WolfRainbow LOVE MarqueeCopper Pipe Japanese Shishi-odoshi Fountain
Add instructable to:
